Classic Audi Ľ Technical Ľ Mech/Tech Ľ Engine » Cooling
Old 09-09-21, 08:31 AM   #11
darreno'd'
Mr Sixty Thousand!!
darreno'd''s Avatar
Thanks
http://www.oesems.co.uk/
Old 12-09-21, 11:23 AM   #12
Here goes -
All taken from front with fan cutting in and out.
T = tank
F = fins
Main rad.
Top to bottom - L to R
T87.5. T87.5. T84.7
F73.6. F74.0. F77.1
T50.3. T47.5. T46.2
Aux rad.
L to R
T75.3. T88.0
Hope this helps.
VBR
Ian
Isimmo is online now   Reply With Quote
Old 12-09-21, 11:33 AM   #13
darreno'd'
Mr Sixty Thousand!!
darreno'd''s Avatar
Thanks Ian, absolutely does, I will do the same later.
Old 21-09-21, 04:39 AM   #14
darreno'd'
Mr Sixty Thousand!!
darreno'd''s Avatar
My results are as follows, car had a good run and also sat in lots of traffic so properly warmed through.
All results left to right as simmos.
Tank l 92 mid 90 r 84
Mid rad L 58 mid 79 r 64
Bottom L 31 mid 26 r 24
Aux rad. L 75 mid 66 r 58
Where the top hose leaves the block was 90
Old 21-09-21, 07:00 AM   #15
Thatís remarkably cold at the bottom isnít it?
Old 21-09-21, 08:58 AM   #16
darreno'd'
Mr Sixty Thousand!!
darreno'd''s Avatar
Yes but seems awfully hot leaving the engine, it triggers the overheat switch on occasion, car runs well so Iím not overly leaning toward head gasket, doesnít have milky oil or use any coolant. Oil temps are normal and the fan cycles like normal. It just bothers me as when youíve had something so long you can tell when itís different. My pondering right now is whether the aux rad is doing too much work and the main not enough as regards flow, in theory with the way the pipes run that could be possible.
Copyright ©2000 - 2021, Jelsoft Enterprises Ltd.
