Members: 14,987 | Total Threads: 40,057 | Total Posts: 470,834 Currently Active Users: 930 (26 members and 904 guests) Welcome to our newest member, anavuzitu |
04-07-13, 05:29 PM | #1 | |
Just wires...
In my B3 80Q where the stereo would go is just the wires......
What kind of job is it to find the right plug and head units.... HELp |
04-07-13, 05:31 PM | #2 |
depends on what head unit you go for or origanal one ?
04-07-13, 05:36 PM | #3 |
I thought about but naaa, maybe a modern pioneer alpine Sony with iPod stuff and stuff, that kind of unit!
04-07-13, 05:47 PM | #4 |
most newish head units have these type of out puts
http://www.ebay.co.uk/itm/ISO-EXTENS...item3a637f9a34 also same as old rover ect .all you need to do is find 12v + earth from car wireing and all speaker wires and cut ends off the new cable and attach to the new harness |
04-07-13, 05:56 PM | #5 |
Alright quite simple then, cheers mate
04-07-13, 06:11 PM | #6 |
The wires- are they all connected to a plug, or completely loose?
04-07-13, 06:20 PM | #7 |
Loose
19-08-13, 06:20 AM | #8 |
All you have to do is to get to nearest junkyard and cut a pair of those ISO connectors from some car - and you will find them in any car which is newer than 15 years. I got mine from Opel Omega. Of course, next thing will be wiring them up which probably won't be as simple as Micky said, depending how properly you will want to do that - in ISO A connector is place for ignition, ground, battery, illumination, antenna power, speed signal [aftermarket radios will unlikely need it, but that wire is probably already hanging there], mute [some aftermarket radios could use that feature, but unless you want to install button in the back for passengers, you won't need it, as it's intended for telephone] and reverse light [needed for navigations, so unneeded for you & harder to properly wire, as it's not in that loom on B3]. Also, there could be a problem with the speakers as well - depending on what you have in the back - if nothing or passive speakers, fine, if original active speakers, you don't have to wire them up to B connector but instead you have to attach a pair of RCA plugs, which is the usual way for aftermarket stereos to output line out.
