Classic Audi Technical Mech/Tech Engine » Hall Sender
Old 14-03-20, 09:40 PM   #1
Sie!
Default Hall Sender
I have a sneaky feeling my hall sender maybe on its way out, I've had intermittent stalling and non-starting, over a period of many years, gradually getting worse... Tried most other things apart from the coil itself - which I may try.
From reading the symptoms online it would figure.
Has anyone had any experience with replacing the sender as opposed to the whole distributor?
Also, the part numbers are a minefield, anyone know a definite distributor part number for a 1985 Audi 80, 1781cc DS motor?
Many thanks,
Sie!
Old 15-03-20, 11:22 AM   #2
86audicoupe
Classic Audi Pervert!
86audicoupe's Avatar
Hi Sie
I had same symptoms as you and came across this website. Have a look here, I知 sure you値l find what you need. Come with a decent warranty too. I copied and pasted their own part number into eBay and found they have an eBay shop which seems a bit cheaper
https://www.ignitioncarparts.co.uk/PartLists.aspx?
Old 15-03-20, 06:20 PM   #3
I've got a hall sender to fit to the distributor for my KV 90.
You need circlip pliers which is why I've been putting it off as I don't have the correct ones.
Looks like 034 998 065 is the right one providing you have 026 905 206 F distributor
I got mine from Amazon of all places. It was around 」40 or so
1988 90 quattro project
Old 17-03-20, 11:52 PM   #4
Sie!
Originally Posted by 86audicoupe View Post
Hi Sie
Ah I did come across that site, great to have your recommendation, and confirmation that I maybe on the right track to solving the problem - very helpful, many thanks
Old 17-03-20, 11:55 PM   #5
Sie!
Again, thank you! With that in mind, I may ensure a replacement complete distributor is available, then try my hand at just replacing the sender - sounds daft but I would like to try and retain as much of the original car as possible... after 35 years I知 not sure how much of my actual 羨udi remains!
Old 18-03-20, 10:43 AM   #6
BackintheFold
Trigger's broom!
Old 18-03-20, 08:50 PM   #7
Sie!
Originally Posted by BackintheFold View Post
Trigger's broom!
Exactly,
