Members: 13,707 | Total Threads: 40,056 | Total Posts: 470,826 Currently Active Users: 709 (19 members and 690 guests) Welcome to our newest member, otuteoveyazi |
19-05-18, 01:40 PM | #21 |
Bugger ! It blew the fuse again
19-05-18, 01:54 PM | #22 |
Bruce, if it’s blowing the fuse straight away it’s a wiring or power surge issue. If the motor was running constantly then blowing the fuse it would be a sign of a vacuum leak.
If the motor got soaked I’d try drying it out and checking for shorting wires/ connections at that end first. |
19-05-18, 02:10 PM | #23 | |
It's got too hot here now so i will get the pump out a bit later, i assume the circuit is live all the time ? I don't understand electrics to be honest unless things get explained in the simplest of ways Should any of the plugs give a reading when not connected (including in the doors) ? |
19-05-18, 03:39 PM | #24 |
The pump is now out of the car, is there any way of seeing the motor ? all i can see is the pcb with the cover off.
19-05-18, 04:31 PM | #25 |
In for a penny in for a pound I just pulled it all apart, what can i put power to the motor with to see if it runs ? the second pcb looks a bit grotty so it could be the pumps the problem.
Any help is much appreciated |
19-05-18, 05:53 PM | #26 | |
Hope you get it sorted Bruce
19-05-18, 06:37 PM | #27 |
Keep going Bruce you'll get there.
19-05-18, 06:38 PM | #28 |
19-05-18, 06:39 PM | #29 |
19-05-18, 06:39 PM | #30 |
