Members: 13,533 | Total Threads: 40,056 | Total Posts: 470,823 Currently Active Users: 738 (24 members and 714 guests) Welcome to our newest member, irakorereh |
05-05-14, 08:07 PM | #1 | |
ur Brake problem
Hi all,
Me again! I have been doing a service on the ur, including the brakes. I have replaced the rear calipers with refurbed 20v & disks/pads, also the front calipers I have refurbiished with a new seal kit sliders/ new pads and disks, new brake fluid. Before I started, taking it to its mot, (after being in storage for 6 months) I was forced to apply the brakes quite hard due to traffic coming to an abrupt stop. Since then, I have the " Attention, brake system defective" warning, the brakes still work ok, albeit a little spongy today until all 4 brakes bed in. Thanks for advice |
05-05-14, 08:09 PM | #2 |
Fluid level ok ? Can't remember if that's a warning for that too
Mr OCD http://s159.photobucket.com/albums/t144/jsquatts/ Daily rs4 b7 with buckets that play havoc with my piles And if you are reading this as James may would say ' you're a cock ' |
05-05-14, 08:27 PM | #3 |
yes, fluid been replaced John
05-05-14, 08:37 PM | #4 |
Please check brake fluid- level switch, I believe.
Attention! Brake system defective- pressure switch on the brake hydraulic assembly. There's 2 switches. One for system pressure, and one for circuit pressure. Dirty switch connections can create a warning. Would bleeding the brakes again help? Possibly. It wouldn't hurt, but maybe irrelevant. On the V8, I get a red flashing warning light, and on the UR, have had an aural brake warning, following an emergency stop (ABS kicking in) Always, it's disappeared in normal driving, even with heavy braking.
05-05-14, 08:42 PM | #5 | ||
The amber warning triangle is constantly on as well |
05-05-14, 08:54 PM | #6 |
Is the wire damaadged on the float
05-05-14, 09:18 PM | #7 |
ok I will check that as well John
Thanks both |
05-05-14, 09:50 PM | #8 |
Just went to the garage to check what was suggested, I took off the 2 spade connectors on the top of brake fluid reservoir, gave them a wire wool clean, and no more warning! so it was a dodgy contact, thanks
05-05-14, 10:24 PM | #9 |
I did wonder .... Had it on one of mine before
