Classic Audi Technical Technical Info » MB instrument cluster lighting
Old 21-05-20, 08:56 AM   #1
BackintheFold
Default MB instrument cluster lighting
I am currently using LEDs to light the cluster. The OEM halogens burn pretty hot.
Trouble is of course that they are undimmable, but that's a small price to pay for
1-the 1 amp permanent saving in current drain.
2-a cooler dashboard.
The ones i used were pretty cheap, and can "flutter" a little, so i may try to spend a bit more on better quality bulbs later.
Any comments appreciated!
Old 21-05-20, 09:46 AM   #2
droopsnoot
I thought some LEDs were dimmable?
droopsnoot is offline   Reply With Quote
Old 31-05-20, 09:08 PM   #3
BackintheFold
I’ll take a look into that. Some are-but I don’t know if they are in this shape.
Old 05-06-20, 06:00 PM   #4
BackintheFold
A quick internet search revealed many people with similar issues.
A canbus compliant led should resolve the issue of flickering.
While it may now draw close to the same current as canbus bulbs have resistors, I wonder
if the heat generated will also increase, as no current will
Be dissipated as light.
Anyone got any ideas? Maybe I can test a canbus compliant bulb and measure its temperature compared to a non compliant one.
