Classic Audi Technical Mech/Tech Engine » Fuel Pipes sizes from the petrol tank. B2 1983
Old 08-11-18, 08:47 PM   #21
jampublic
jampublic's Avatar
Originally Posted by billy_bunter View Post
I think the the pipe you are after is 16 in the diagram below
https://audi.7zap.com/en/rdw/audi+80.../201-36000/#16
Part number 811 201 218 B which is NLA. Last used in 87 according to ETKA. Nothing on german ebay/google under that part number. Looks like vw parts are different as the fuel tank is positioned differently. Closest is the Scirrocco. There are more than a few breaking the cars and by the looks it is fitted to all the 4 cylinder injection engines of that era.
This looks like my layout & no.22 is my issue
jampublic is offline   Reply With Quote
Old 08-11-18, 08:50 PM   #22
jampublic
jampublic's Avatar
custom braided versions with the correct ends already made up.
Custom correct ends that can slip on to metal barb ends/metal nipples? Sounds perfect what is the correct end?
I only see the standard choice of pipe work on Vipers page, but interested in this custom correct end information.
Thank you
JAM
Old 08-11-18, 09:08 PM   #23
billy_bunter
so the part number for 22 is...
N0203001 11X3,5 supplied in 5m rolls (originally) shorten to 240mm. VW heritage supply this...
https://www.vwheritage.com/n0203001-...meter-vw-spare
Clamps are:
N10258201 12-22X9X0,4 12mm to 255mm bore, 9mm wide band, .4mm thickness of band
Again Heritage-
https://www.vwheritage.com/n10258201...-25mm-vw-spare
Is that what you have on the car? You initial post was talking about crimped joints?
billy_bunter is offline   Reply With Quote
Old 08-11-18, 09:12 PM   #24
jampublic
jampublic's Avatar
yep..will just blow off the connections!
Clamps are:
Again Heritage-
Exactly what i have & fails to do the job!
Old 03-12-18, 07:02 PM   #25
jampublic
jampublic's Avatar
So I found my problem, it was quite simple! It was just me...
I simply tightened up all the fixings & the issue was solved, but then noticed a smaller leak around the washers at the neck of the banjo fitting. I removed the fuel filter again to tighten & replace the washers, then f__ked the fuel filter & snapped the banjo fitting
Waiting on new parts & still looking for a replacement banjo fitting.
Just call me Frank Spencer, because some mothers do have them!
You live & you learn
Old 04-12-18, 09:08 PM   #26
billy_bunter
Sometimes we make our minds up about a problem before we really explore all the options and thus get stuck. I am murder for it.
Hope you get it fixed soon..
