Members: 13,639 | Total Threads: 40,056 | Total Posts: 470,826 Currently Active Users: 765 (17 members and 748 guests) Welcome to our newest member, uyowabexugem |
04-11-09, 03:27 PM | #1 | |
Obsolete parts - from Ingrams Audi
parts maanger at Ingrams has very kindly compiled this list of parts found in a few cason containers.
there are about 600 parts here but unfortunatley he didnt have time to separate into model specific. if anyone IS BORED ONE EVENING WHO HAS ETKA and could split up to respective car models I would be gratefull. contact him direct on Direct Dial: 01292 270615 Fax Number: 01292 270601 christopher.caldwell@ingram.audi.co.uk IF you contact him give me a mention please, so he knows I am trying to help sell these parts ( no financial gain to me) ok.... now for the list. 133955435 COVER a OBS25 4 0.1 0.4 0.21 165906381 RELAY a OBS34 1 6.96 6.96 7.45 431505172 MOUNTING a OBS17 1 3.55 3.55 4.1 431898550 REPAIR KIT a OBS6 1 8.32 8.32 9.64 433807253 BRACKET a OBS1 3 2.29 6.87 2.81 443201137 INSERT a OBS28 1 3.29 3.29 3.24 443399419 MOUNTING a OBS22 2 20.25 40.5 14.12 443853805 SCREW a OBS25 10 1.04 10.4 0.64 444941115 LENS a OBS20 1 11.59 11.59 12.77 444941116 LENS a OBS10 1 12.43 12.43 13 445827551 STRUT a OBS40 2 23.72 47.44 21.87 447615424 HOUSING a OBS34 1 112.44 112.44 102.49 811412319 STOP a OBS13 1 3.13 3.13 3.33 813972926 HOUSING a OBS31 1 3.11 3.11 3.39 855407469 LINK a OBS38 2 8.83 17.66 12.97 856721335 CABLE CL t OBS5 1 16.25 16.25 23.32 857051560 SPARE MAST a OBS40 3 14.08 42.24 14.24 893121273 RUBBER MOUNTING a OBS38 2 5.45 10.9 5.78 893407469 CON LINK a OBS35 1 23.85 23.85 26.24 893599131 SUPPORT T OBS23 1 18 18 25.32
04-11-09, 03:29 PM | #2 |
893711191 BUSH a OBS29 1 0.41 0.41 0.4
893803777 BRACKET a OBS5 1 10.87 10.87 12.38 893853582 SPRING a OBS11 1 0.22 0.22 0.22 893905851 STEER LOCK a OBS38 1 39.46 39.46 45.53 893919067 WARN LIGHT a VBBOX31 1 50.32 50.32 53.89 893919069 KNOB a OBS27 1 2.27 2.27 3.01 893919511 TEMP GAUGE a OBS3 2 33 66 35.64 893941699 FOG LAMP a OBS12 1 40.89 40.89 39.87 893953050 TURNSIGNAL a OBS33 2 22.95 45.9 11.82 895881621 GUIDE a OBS28 3 0.43 1.29 0.58 895959613 POTENTIOMETER a OBS6 2 49.22 98.44 38.41 896941116 LENS a OBS28 1 23.98 23.98 26.49 23156644920 A3 CONCERT RADIO MAN a OBS28 1893711191 1.5 1.5 5 017525291a FLANGE t OBS19 1 62.16 62.16 150.36 018409399B SEAL a OBS39 2 6.81 13.62 7.62 026109243J ROLLER a OBS40 1 20.01 20.01 17.99 026121133C FLANGE a OBS12 1 18.52 18.52 19.57 026129717F GASKET a OBS12 1 2.32 2.32 2.94 026133370F HOSE a OBS8 1 11.23 11.23 13.94 026133642G CONN HOSE a OBS19 1 4.39 4.39 6.02
04-11-09, 03:30 PM | #3 |
026198025A REPAIR KIT a OBS37 1 1.89 1.89 4
026198049A REPAIR KIT a OBS12 2 5.01 10.02 6.9 028121145J FLANGE QUICK CLUTCH a OBS19 2 22.2 44.4 23.33 028141035EX CLUTCH PLT * a OBS17 1 39.88 39.88 15 0 0 43.12 028198141BX CLUTCH KIT * a OBS20 1 80.25 80.25 20 0 0 84.52 028903119R RIBBED BELT PULLEY a OBS36 1 8.72 8.72 12.38 02d525351f FLANGE SHAFT a VBBOX21 2 39.9 79.8 79.97 02K301205A COVER a OBS30 1 64.4 64.4 71.58 030103531E BOLT HEX HD SHOULDER a OBS34 1 1.09 1.09 1.39 034103221C PIPEBREATH a OBS40 1 7.86 7.86 7.76 035103235A HOSE a OBS20 1 3.02 3.02 4.67 035121093K BRACKET a OBS28 1 0.78 0.78 1.3 035121448B WATER HOSE a OBS24 1 4.46 4.46 4.93 035VAG720 ADAPTER a OBS37 1 2.38 2.38 2.28 036145933H BELT a OBS40 1 9.35 9.35 9.16 036998051A REPAIR KIT T OBS6 1 1.24 1.24 6.19 036998051B REPAIR KIT a OBS6 1 1.61 1.61 4.98 037131351c AIRCONTROLVALVE a VBBOX28 1 98.01 98.01 36.32 038130073AR INJECTION PUMP a OBS24 1 342.99 342.99 395.01 038130079EX PUMP* * Z OBS23 2 249.75 499.5 100 0 0 273.03 038198051b SEAL KIT a OBS16 2 2.09 4.18 7.55 038198051C SET OF SEALS a OBS16 2 7.25 14.5 13.03 045131501D EGR VALVE a OBS26 1 80.3 80.3 124.9 048109243a ROLLER a OBS31 1 19.65 19.65 17.52 048121056A WATER HOSE a OBS19 1 3.57 3.57 3.3 048133747A FUEL PIPE a OBS31 1 18.44 18.44 22.09 049903119L PULLEY a OBS20 1 7.2 7.2 17.95 051133471AX AIR FLOW * a OBS25 1 52.5 52.5 145 0 0 441.08 051VAG025 CASSBOXA4 a OBS16 1 14.8 14.8 14.8 053911023ax STARTER * a OBS18 1 81.92 81.92 30 0 0 76.36 055905225B ROTOR a OBS25 1 2.22 2.22 3.32 057145100C VAC PUMP a OBS17 1 93.01 93.01 103.56 058903018x ALTERNATOR * a OBS36 1 89.6 89.6 40 0 0 125.19 058905409A IGNITION LEAD a OBS27 2 15.16 30.32 16.47 059103381A PLUG a OBS5 1 2.55 2.55 3.52 068121133M FLANGE a OBS30 1 23.2 23.2 29.25 068121145K FLANGE a OBS30 1 20.06 20.06 19.81 068130301E PRESS PIPE a OBS4 2 16.1 32.2 23.42 06a906033j CONTROL UNIT a VBBOX21 1 224.96 224.96 350.3 06B115130 CHAIN a OBS21 1 14.67 14.67 13.27
04-11-09, 03:32 PM | #4 |
06B115441C GASKET t OBS21 1 4.03 4.03 3.32 06B133751AP PUMP a OBS23 1 25.62 25.62 38.12 074906461B AIR METER a OBS33 1 151.6 151.6 144.13 077115136A BEARING T OBS40 1 28.94 28.94 0 077129717Q GASKET a OBS19 1 7.06 7.06 6.19 078103483j GASKET a OBS19 1 4.81 4.81 4.21 078103547F PARTITION a OBS23 1 4.88 4.88 7.97 078109243K ROLLER t OBS40 1 18.71 18.71 17.52 078115189H GASKET a OBS31 1 2.5 2.5 2.31 078121071bs PIPE a VBBOX24 1 56.98 56.98 60.81 078133062B THROTTLEVALVEADAPTOR a OBS18 1 322.63 322.63 448.38 078141117nx CLUTCH PLATE * a VBBOX24 1 71.05 71.05 15 0 0 38.08 078903119C RIBBED VBELT PULLEY a OBS5 1 25.5 25.5 36.09 078903137BD RIBBED V-BELT FOR AC a OBS32 1 17.66 17.66 17.2 078903137BH RIBBED V BELT a OBS24 1 15.52 15.52 19.15 092VAG245 TOW MIRROR a OBS10 2 8.33 16.66 7.77 095927321B SENDER a OBS10 1 20.72 20.72 28.43 107837064CA LOCK CYLINDER a OBS31 5 31.4 157 36.6 107862055ca LOCK CYLINDER a OBS17 1 48.22 48.22 81.18 107905855CC LOCK CYLINDER a OBS25 1 49.38 49.38 67.34 171407291B CLIP a OBS23 1 1.79 1.79 1.49 191881479LX6 COVER T OBS35 2 3.57 7.14 4.01 191919149D DISTANCE SENSOR a OBS16 2 15.95 31.9 11.63 1c0920900c INSTRUMENT CLUSTER a VBBOX20 1 147.84 147.84 208.61 1E0853675739 INSCRIPTION BRI CHRM a OBS31 1 4.22 4.22 0 1H0035551 AERIAL ADAPTOR a OBS19 2 16 32 18.66 1H0498201 BOOT WITH PARTS a OBS4 1 11.25 11.25 8.3 1J0145834S HOSE a OBS31 1 20.62 20.62 20.37 1J0422812A TIERODEND a OBS29 1 10.84 10.84 12.83 1J0612041BS VACUUM PIPE a OBS18 1 6.59 6.59 12.55 1j0615123d CALIPER t OBS17 1 69.62 69.62 45.08 1j0615124d CALIPER a OBS17 1 69.62 69.62 45.08 1J0885471A LOCK SEAT a OBS33 1 22.28 22.28 25.81 1J0955531 CONTROL UNIT a OBS31 1 20.07 20.07 0 1J0972329 PLATE a OBS31 1 0.7 0.7 0.69 1J2721115G BRACKET a OBS32 1 36.79 36.79 36.34 1K0864227A4PK BRACKET a OBS28 1 0.49 0.49 0.59 1U0010253E STICKER a OBS27 1 0.27 0.27 0.27 1U0823574 bracket T OBS40 2 1.48 2.96 1.46 1U6810958B SEAL a OBS32 1 10.58 10.58 8.66 321615312A COVERPLATE a OBS22 1 7.53 7.53 15.7 3A0953049A TURNSIGNAL a OBS28 1 10.34 10.34 9.53 3B0051530 NAV KEY a OBS21 2 4.43 8.86 5.48 3B0513031R SHOCK ABS T OBS28 2 45.93 91.86 34.14 3B0823301 HINGE a OBS35 1 9.24 9.24 10.95 3B0823302 HINGE a OBS35 2 8.65 17.3 10.95 3D00614932LP FIXINGS 2001 a OBS8 1 2.12 2.12 4.11 443199381J RUBBER MOUNTING a OBS39 1 22.37 22.37 18.9 443201140B LOCK RING a OBS24 1 7.65 7.65 10.85 443201220D FUEL PIPE a OBS10 1 21.53 21.53 34.09 443399415a MOUNTING a OBS23 2 10.6 21.2 14.12 443505171f MOUNTING a OBS39 1 15.99 15.99 17.24 443837243A RIVET a OBS25 1 1.19 1.19 1.4 443857561J3VF BRACKET S VISOR/GREY a OBS28 1 5.11 5.11 5.24 443862227a ABSORBER a OBS3 1 10.5 10.5 12.86 443905851B HOUSING a OBS12 1 31.82 31.82 41.52 443905855a LOCK CYL a OBS12 1 22.22 22.22 30.2 443927351B CONTRLUNIT a OBS14 1 37.5 37.5 31.73 444721507B ACC PEDAL a OBS8 1 34.81 34.81 35.14 444905851a LOCK CYL a OBS14 1 45.91 45.91 45.3 4A0011031B JACK a OBS40 1 24.63 24.63 24.33 4A0131737A CAP NUT a OBS13 2 3.29 6.58 3.69 4a0201801 CONTAINER a VBBOX11 1 49.89 49.89 75.26 4A0253147 RETAINING RING a OBS23 1 4.52 4.52 4.91 4A0413031J SHOCKABSOR t OBS5 1 119.35 119.35 75.22 4A0721261 SLAVE CYL a OBS39 1 39.61 39.61 37.85 4A0805869B SUPPORT a VBBOX21 1 59.97 59.97 61.52 4A0831412D HINGE t VBBOX07 1 38.5 38.5 54.46 4A0853825H CLIP a OBS40 1 0.45 0.45 0.74 4a0857706afv04 THREE PNT STBLT/BLK a OBS32 1 62.32 62.32 111.32 4a0867340 NUT a OBS1 20 0.24 4.8 0.1 4a0941699 HALOGEN FOG LAMP a OBS15 1 86.29 86.29 58.04 4A0972244 HOUSING a OBS25 1 1.89 1.89 2.64 4a2201529f FUEL PIPE a VBBOX24 1 39.12 39.12 46.91 4a2721507c ACCELERATOR PEDAL t OBS31 1 37.41 37.41 43.51
04-11-09, 03:33 PM | #5 |
4A2857501F3FZ REARVIEWMIRRORHOUSG a OBS7 1 75.75 75.75 79.14 4A2857536AB MIRROR GLASS a OBS3 1 31.5 31.5 28.98 4A5035509 ELECAERIAL a OBS5 1 111.49 111.49 119.23 4A5853743R2ZZ INSCRIPT T OBS36 1 2.32 2.32 2.26 4A5959489B MICRO SWITCH a OBS24 2 8.81 17.62 11.08 4a9035501 100AERBASE a OBS24 5 40.31 201.55 39 4a9513031b SHOCK ABSORBER t OBS1 2 57 114 28.31 4A9845453D CLAMPING STRIP T OBS12 1 19.47 19.47 20.26 4A98537412ZZ INSCRIPTION a OBS22 1 3.99 3.99 4.94 4B0035399C SPEAKER a OBS23 1 12.92 12.92 18.6 4B00354362ET DOORWOOFERRRSLATE a OBS38 1 2.61 2.61 3.13 4B00614932LP FIXING KIT t OBS10 1 1.78 1.78 4.11 4B0201220C FUEL LINE T OBS29 1 15.84 15.84 18.56 4B0201550 FUEL FILLER CAP a OBS23 1 13.11 13.11 15.42 4B0711327D42H COVER a OBS16 1 25.16 25.16 39.26 4B0711463J6DP HAND BRAKE a OBS14 1 8.16 8.16 11.44 4B0807681S01C GRILLE a OBS39 1 8.65 8.65 9.63 4B0815743K7H5 TRIM a OBS18 1 32.9 32.9 47.71 4B0839207GRU HANDLE a OBS39 1 16.07 16.07 17.62 4b08535807dl TRIM a OBS20 1 8.6 8.6 8.74 4B0853812 DUST COVER a OBS20 1 0.21 0.21 0.28 4B0854494 DUST COVER T OBS8 1 0.81 0.81 1.34 4B08575512PL VIZOR(VANILLE) a OBS30 1 26.42 26.42 30.15 4B08576351ZS COAT HOOK BISQUIT a OBS6 1 7.49 7.49 10.24 4B0857755M01C BLACK BUTTON BUCKLE a OBS23 1 16.38 16.38 23.52 4B0857967L5TQ TRIM a OBS18 1 37.26 37.26 38.08 4b08625337pe HOLDER a VBBOX28 3 10.73 32.19 14.5 4B08632775PR CIGARETTE LIGHTER a OBS18 1 2.95 2.95 5.24 4B0863277AB98 TRIM SATIN a OBS12 1 3.48 3.48 5.31 4B0867191 BRACKET t OBS19 1 1.21 1.21 1.34 4B08689784ZE SHELF WITH COVER T OBS26 1 24.56 24.56 31.62 4B08813471EJ CHANNEL COVER ONYX a OBS11 2 1.95 3.9 2.9 4B08814456DP FRICTION PAD a OBS11 1 3.4 3.4 5.14 4B08856074SM TRIM a OSB4 2 1.73 3.46 10.9 4B08859965FS TRIM a OBS6 2 11.81 23.62 10.97 4B0898399 GUIDEPIECE a OBS31 1 1.68 1.68 2.12 4b0907487d CONTROL UNIT a VBBOX05 1 87.32 87.32 98.81 4B0919051F FUEL UNIT a VBBOX27 1 141.17 141.17 125.17 4B0919275C ULTRASONIC SENSOR t OBS32 1 26.66 26.66 37.87 4B0919283 CONTROL UNIT a OBS7 1 72.45 72.45 57.12 4b0919910fx CLUSTER * a OBS4 2 159.9 319.8 180 0 0 177 4b0919930x COMBI INSTRUMENT * a VBBOX22 1 255.96 255.96 230 0 0 449.75 4B0927807C SPEED SENSOR a OBS19 1 68.4 68.4 79.71 4B0951229A SPRING CLIP a OBS23 3 2.25 6.75 5.34 4B0955275GRU CAP a OBS30 1 4.54 4.54 5.27 4B0959501A CONTR MOD. a OBS13 1 79.08 79.08 87.72 4B0959655M MODULE a OBS38 1 212.06 212.06 257.64 4B0959801B WINDOW LIFTER a OBS36 1 78.57 78.57 104.77 4B0959831AB98 BUTTON a OBS29 1 7.1 7.1 9.34 4B1422893Q FLEX. HOSE a OBS30 1 84.28 84.28 95.82 4B2260709 PIPE a OBS33 1 30.46 30.46 30.51 4B2713110 COVER a OBS4 1 81.9 81.9 72.6 4B2819422A01C COVER a OBS38 1 3.5 3.5 4.18 4B28571315FS GLOVEBOX a VBB0X02 2 22.1 44.2 28 4B5035225H BOOSTER a OBS32 1 33.12 33.12 34.94 4B5827552F STRUT a OBS10 4 11.2 44.8 11.34 4B5853273C5PV CORNER TRIM a OBS13 1 14.25 14.25 17.99 4B5853273DY9B TRIM a OBS13 1 16.74 16.74 17.99 4B58533452ZZ MOLDING a OBS14 2 23.55 47.1 32.89 4B585756901C TRIM a OBS5 1 2.05 2.05 3.05 4B5857569AQ4 BLACK TRIM a OSB4 1 1.88 1.88 2.59 4B5943021 LICENCE PLATE LIGHT a OBS36 1 4.63 4.63 4.27 4B5945221 BULB HOLDER a OBS19 1 5.18 5.18 6.63 4B5962115A B/L ELEMENT t OBS19 1 14.43 14.43 23.77 4B5962115B ELEMENT t OBS32 1 19.34 19.34 20.81 4B9853273EY9B TRIM a OBS16 2 13.48 26.96 17.99 4B9853274AY9B CORNERTRIMBLACK z OBS8 1 15.01 15.01 17.05 4B9853274EY9B TRIM a OBS18 3 15.02 45.06 17.99 4b985780741a SEAT BELT a VBBOX11 1 81.62 81.62 111.32 4B9857807V04 SEAT BELT a OBS39 1 92.1 92.1 111.32 4B98639957EX TRIM a OBS10 1 12.21 12.21 4.14 4B986399590G COVER T OBS11 1 12.18 12.18 4.14 4D0011031D JACK a OBS16 1 43 43 52.74 4D0035225P AERIAL BOOSTER T OBS30 1 37.24 37.24 39.44 4D0035225Q AERIAL BOOSTER a OBS28 1 44.89 44.89 47.48 4D0035530E SWITCH BOX a OBS29 1 66.46 66.46 69.19 4D0035925A BRACKET a OBS28 1 1.43 1.43 1.59 4D0698137 LOCKING WHEEL BOLTS! a OBS25 6 31.74 190.44 42.25 4d0698151k BRAKE PADS a VBBOX11 2 106.6 213.2 49.65 4D0698151P BRAKE LINING a OBS32 1 76.11 76.11 55.32 4D0803583G PLUG a OBS33 1 0.45 0.45 0.51 4d0839016d DOOR LOCK a VBBOX28 1 47.4 47.4 47.38 4D0853736E2ZZ NAME t OBS17 1 6.69 6.69 8.51 4D08549603FZ LINING a OBS28 1 12.72 12.72 17.08 4D0857585A CAP a OBS24 1 0.53 0.53 0.64 4D08643751WV TRIM a OBS28 1 38.34 38.34 42.27 4D0881326AQ06 ECRU SEAT TRIM PANEL a OBS8 1 28.86 28.86 42.49 4D0881463CEC3 PLATINUM CAP a OBS31 1 15.01 15.01 18.96 4D0881469EC3 PLATINUM CAP a OBS31 2 11.03 22.06 13.68 4D0919283 PARKINGAIDCONTROLUNI a OBS6 1 45.75 45.75 85.6 4D0941295 MOTOR a OBS20 1 24.05 24.05 50.12
04-11-09, 03:34 PM | #6 |
4D094150301C REAR WINDOW a OBS9 1 24.42 24.42 24.06
4D0941699 FOG LAMP a OBS21 1 45.54 45.54 44 4D0941777 TRIM a OBS35 1 5.72 5.72 6.93 4d0951173b CONTROL UNIT a VBBOX21 1 191.45 191.45 142.62 4D0959565G01C SWITCHREARVIEWMIRROR a OBS24 1 25.41 25.41 36.99 4D0959802H WINDOW MOTOR a OBS20 1 93.74 93.74 95.48 4E0422376 COVER a OBS40 1 3.13 3.13 3.01 4E08537412ZZ NAME a OBS35 1 3.7 3.7 4.58 4F0857536B MIRROR a OBS35 1 144.31 144.31 156.51 4Z7422893C FLEX. HOSE a OBS18 1 58.44 58.44 100.06 4Z7853979 FOIL a OBS39 1 6.69 6.69 6.6 4Z8422891B HOSE a OBS18 1 40.1 40.1 73.4 4Z8955408A WIPER ARM a OBS8 1 11.47 11.47 15.69 5P0919237 KEY SWITCH a OBS35 2 17.8 35.6 18.96 6K3837223 ECENTRIC a OBS33 1 0.5 0.5 0.48 6N0972575 CONNECTOR t OBS33 6 0.75 4.5 1.07 6Q0121206G BRACKET a OBS39 1 5.35 5.35 5.4 6U0955529 RELAY a OBS23 1 7.57 7.57 7.57 811609722d BRAKECABLE a OBS5 1 5.63 5.63 8.26 811611775A BRAKE HOSE a OBS35 1 7.44 7.44 5.22 85394153101C SWITCH a OBS5 1 18.75 18.75 15.13 855253137A WASHER a OBS40 2 2.33 4.66 2.07 855819375F WATER HOSE a OBS39 1 25.66 25.66 30.39 855831711A SEAL a OBS5 1 34.5 34.5 33.12 857199415B MOUNTING a OBS35 2 6.7 13.4 7.5 857853841A MOLDING a OBS23 1 7.25 7.25 0 893411327C MOUNTING a OBS10 5 1.48 7.4 1.68 893411327D MOUNTING a OBS39 1 2.82 2.82 2.98 893412033e STRUT a VBBOX21 1 142.55 142.55 102.35 893412131B BUMP STOP t OBS36 1 6.44 6.44 7.22 893498099gx WHEEL SHAFT * a VBBOX21 1 72.5 72.5 70 0 0 68.68 893501499A TIE ROD a OBS10 1 75 75 50.53 893513031AC SHOCK ABS t OBS17 1 55 55 48.73 893711184C BUSH t OBS30 1 0.97 0.97 1.12 893837063H LOCK BARREL a OBS8 1 16.54 16.54 17.95 893857535F MIRROR a OBS30 4 24.09 96.36 26.04 893857703B041 LAP BELT a OBS4 1 48.83 48.83 39.48 893919511A TEMP GAUGE a OBS38 1 32.43 32.43 31.08 894419802A TIE ROD a VBBOX15 2 58.53 117.06 55.66 894941116A LENS a OBS12 1 13.88 13.88 11.67 895413503C SHOCK ABSORBER t OBS8 1 67.5 67.5 56.18 895827563A01C a OBS4 1 2.05 2.05 3.76 895853215BGRU TRIM a OBS18 1 11.27 11.27 12.88 895853509GRU MOULDING a OBS10 1 39.05 39.05 45.86 895881607A TRIM a OBS28 2 1.58 3.16 2.31 8a00354123vf AU80RDWFR a OBS3 1 25.21 25.21 32.4 8A0133511 FUEL FILTER a OBS8 2 11.66 23.32 8.09 8A0399300B SHIELD a OBS28 1 3.91 3.91 4.01 8A0407465C CONNECTING LINK a OBS35 1 22.74 22.74 27.88 8A0407615C WHEEL HUB a OBS30 1 61.34 61.34 58.79 8A0422897B PRESSURE PIPE a OBS31 1 28.21 28.21 32.41 8A0609735B BRAKE CABLE BRACKET t OBS28 2 10.07 20.14 11.1 8a0698151e BRAKES a VBBOX31 2 119.35 238.7 124 8a0805962e AIR GUIDE a OBS5 1 6.34 6.34 10.58 8A0819371K WATER HOSE a OBS8 1 16.32 16.32 23.1 8A0853205 SEAL a OBS32 1 8.34 8.34 15.79 8A08537372ZZ INSCRIPT a OBS17 1 5.44 5.44 4.17 8a0941699 HALOGEN FOG LAMP a OBS37 1 53.75 53.75 58.82 8A0953056A TURNSIGNAL a OBS28 1 16.64 16.64 12.15 8A0959655C CONTROL UNIT AIRBAG a OBS29 2 360.6 721.2 241.07 8a5827302 HINGE FLAP a OBS3 1 34.54 34.54 38.68 8d003542001c TRIM t OBS3 1 1.86 1.86 4.75 8D0093055 WARNINGTRIANING a OBS36 1 9.81 9.81 9.32 8D0121107M HOSE a OBS18 1 4.07 4.07 5.51 8D0199306G SUPPORT a OBS13 1 19.43 19.43 27.34 8D0199382M HYDRO-MOUNTING a OBS20 1 47.13 47.13 53.68 8d0399419b MOUNTING t OBS22 2 8.52 17.04 20.11 8D0411357 CLAMP a OBS21 1 1.22 1.22 1.19 8D0413031AC SHOCK ABSORBER t OBS6 1 41.25 41.25 36.16 8D0413031BK GAS SHOCK ABSORBER T OBS40 1 39.9 39.9 29.37 8D0422891C RETURN HOSE a OBS16 1 27.31 27.31 17.98 8D0501543D BRACKET a OBS12 1 21.18 21.18 28.82 8D0512127 CAP a OBS6 1 0.91 0.91 0.72 8D0601165K8AU WHEEL CAP a OBS38 1 13.08 13.08 13.26 8d0601170a7zj WHEEL CAP a OBS35 2 5.56 11.12 5 8d0601173az37 CAP - WHEEL BOLT a OBS27 35 0.23 8.05 0.14 8D0615134A BRACKET a OBS33 1 2.4 2.4 2.37 8D0711305F HANDBRAKE LEVER a OBS20 1 20.17 20.17 28.36 8D0711463B4EM H/BRAKE BOOT ONYX a OBS25 1 5.08 5.08 6.86 8D0804297 PLUG t OBS21 1 1.02 1.02 1.22 8D0806356B MEMBER a OBS12 1 16.28 16.28 21.95 8D0807134C BRACKET BUMPER a OBS39 1 28.24 28.24 24.39 8D0820193A DRIER UNIT a OBS22 1 47.36 47.36 57.43 8D082095101C AIR VENT a VBBOX19 1 46.78 46.78 62.99 8D0823725A GASKET a OBS10 4 3.81 15.24 4.33 8D08370194PN OPERATINGLEVERGREY a OBS34 1 12.93 12.93 8.34 8D0839015A LOCK a OBS15 3 44.02 132.06 37.1 8D0853622 NUT a OBS20 1 0.3 0.3 0.08 8D0853736C2ZZ BADGE a OBS40 1 11.32 11.32 14.35 8d0857706a9sv SELT BELT 3 POINT a VBBOX15 1 73.15 73.15 111.32 8D0857951B8DE ASHTRAY a OBS21 1 22.35 22.35 21.98 8D0857961ABE5 ASHTRAY a OBS27 1 8.89 8.89 11.21 8D0862055B LOCK CYL WITH KEYS a OBS11 1 53.55 53.55 77.19 8d0862257 PUMP a VBBOX21 1 206.46 206.46 245.82 8d0862533e6dp HOLDER a OBS30 1 12.03 12.03 14.5 8D0863284C3SL TRAY a OBS11 2 26.64 53.28 35.42 8D0863284C4PH TRAY T OBS23 2 26.88 53.76 35.42 8d0863284c5fs TRAY a OBS14 1 26.64 26.64 35.42 8D0864245AU29 ARMREST a OBS11 1 28.3 28.3 30.09 8d0864245ggsp ARMREST a OBS3 1 25.5 25.5 30.09 8D0864261H3ZQ FRAME a OBS12 1 32.56 32.56 49.62 8D0864273 BRACKET a OBS24 3 8.8 26.4 12.92 8D0880242AA SIDE AIRBAG a VBBOX23 1 132.84 132.84 148.78 8D0907557CX CONTROL UNIT * a VBBOX31 2 235.08 470.16 300 0 0 441.46 8d0919035ax COMBI INSTRUMENT * a OBS9 1 173.25 173.25 115 0 0 185.19 8D0919303 LIGHTER a OBS19 3 6.66 19.98 10.12 8D0919930NX COMBI INST * a OBS15 1 277.83 277.83 255 0 0 385.89 8D0927133B01C SWITCH a OBS9 1 10.73 10.73 14.74 8D094151601C COVER a OBS9 1 1.27 1.27 2.08 8D0941700B FOGLAMP a OBS37 1 46.76 46.76 47.72 8D0941700E FOG LAMP a OBS25 1 46.6 46.6 48.92 8d0947111gp21 READING LIGHT a OBS5 1 27.75 27.75 31.08 8d0947111hbq1 LIGHT a OBS3 1 18.75 18.75 25.19 8D0951177 MOVEMENT DETECTOR T OBS21 1 45.24 45.24 67.95 8D0951178 MOVEMENT DETECTOR a OBS21 1 45.24 45.24 67.95 8D0959455B ELECTRIC FAN a OBS4 1 113.25 113.25 96.59 8D0959591A MOTOR a OBS15 2 150.19 300.38 203.21 8D0998521 KIT a OBS4 1 21.75 21.75 32.24 8d2819075a01c TRIM a OBS5 1 5.63 5.63 7.48 8D2837020A6QL OP/LEVERMINERVA a OBS35 1 9.22 9.22 8.96 8d2867172gw18 FINGER PLATE a OBS3 1 4.13 4.13 3.97 8D5035115A BRACKET a OBS26 1 26.79 26.79 31.7 8d5035225 BOOSTER a OBS19 1 31.07 31.07 33 8D5035225E ARIEL AMPLIFIER a OBS36 1 31.26 31.26 29.6 8D50354052ET GRILLE T OBS30 1 6.34 6.34 6.6 8d5055203gc A47PINELE a VBBOX31 1 37.21 37.21 43.41 8D5055204GA A4SAL13PIN a OBS8 1 50.07 50.07 50.19 8D5513031H DAMPER t OBS30 2 34.55 69.1 27.63 8D5853274C01C TRIM SATIN BLACK a OBS10 1 4.66 4.66 11.4 8D5853743B2ZZ INSCRIPTION t OBS37 1 2.38 2.38 3.17 8d9035113 A4AV BRKT a OBS3 1 11.73 11.73 12.89 8D9513031C GAS FILLED T OBS19 1 55.83 55.83 30.3 8d9827299 HINGE a OBS31 1 4.31 4.31 5.99 8D9827552D GAS FILLED STRUT a OBS16 3 12.47 37.41 11.67 8D9827552G GASFILSTRU a OBS40 1 12.85 12.85 13 8D9827565C HANDLE a OBS39 1 22.79 22.79 25.35 8D9827565H LOCK a OBS12 1 21.26 21.26 25.35 8D9857805D2RQ BELT T OBS25 1 71.52 71.52 79.89 8D9857806D2RQ BELT T OBS25 1 71.52 71.52 79.89 8D9857806D41A SEAT BELT a OBS13 1 54.67 54.67 86.16 8E0035399 SPEAKER a OBS40 1 8.06 8.06 7.96 8E0093108 FIRSTAIDKT a OBS10 1 11.03 11.03 12.35 8E0103927A COVER a OBS33 1 8.83 8.83 10.54 8E0121403A RESERVOIR a OBS19 2 6.66 13.32 8.96 8E0201317N SENDER a VBBOX10 1 34.24 34.24 42.55 8E0422821 TIE ROD a OBS39 1 12.11 12.11 12.81 8E0422909 CLIP a OBS28 10 0.45 4.5 0.63 8E0609743 BOOT a OBS31 11 0.77 8.47 0.95 8E0615124 PISTON HOUSING a OBS27 2 41.05 82.1 37.67 8E0615301F MOD. BRAKE DISC a VBBOX27 4 28.5 114 28.5 8E0803126C BRACKET t OBS11 1 18.76 18.76 22.4 8E0805163 CLIP a OBS34 1 0.25 0.25 0.26 8E0805499 SECURING PLATE a OBS29 1 2.85 2.85 4.43 8E0805500 SECURING PLATE a OBS29 1 2.85 2.85 4.43 8E0807454 GUIDE PIECE a OBS37 3 2.95 8.85 3.74 8e0820043b5pr HEATER CONTROLS a VBBOX34 1 351.96 351.96 317.91 8E0839207 DOOR HANDLE BLK a OBS37 1 14.13 14.13 18.08 8E0857536AC MIRROR a OBS37 1 144.31 144.31 156.51 8E0857755C01C BUCKLE a OBS20 1 13.26 13.26 17.1 8E0857951G4PK ASHTRAY a OBS23 1 42.48 42.48 47.57 8E0857967H5TQ COVER T OBS26 4 35.58 142.32 40.23 8E0862153 VALVE a OBS37 1 6.45 6.45 7.46 8E0863278BE73G KNOB a OBS31 1 49.81 49.81 54.05 8E0863278BM86E KNOB a OBS27 2 47.81 95.62 48.14 8E0863278Q69Y GEARSHIFT a OBS21 1 23.85 23.85 37.58 8E0863284A5PR TRAY a OBS27 1 27.12 27.12 32.87 8E0880201J6PS AIRBAG a VBBOX05 1 304.56 304.56 324.6 8E0881254A4PK LEVER a OBS20 1 3.45 3.45 4.97 8E0881254C4PK HANDLE a OBS33 1 4.84 4.84 5.43 8E0881326H4PK TRIM PANEL a OBS14 1 14.43 14.43 20.68 8E0881793A4PK TRIM a OBS20 1 3.55 3.55 5.72 8E0883253A6PS HANDLE a OBS20 2 7.9 15.8 12.42 8E0906627B CONVERTER a OBS19 1 16.51 16.51 23.38 8E0906628A CONVERTER a OBS40 1 21.73 21.73 24.68 8E0907279D LEISTMODUL a OBS15 3 66.51 199.53 151.91 8E0919673AH SENDER T OBS19 1 26.8 26.8 42.55 8E0919673AL SENDER a OBS27 2 34.25 68.5 36.66 8e0927807b SPEED SENSOR a VBBOX05 1 40.28 40.28 42.63 8E0953229 SWITCH a OBS24 1 8.81 8.81 9.08 8e0959433ag CONTR UNIT a VBBOX07 4 118.47 473.88 106.67 8E0959761E MOTOR a OBS18 1 71.28 71.28 98.26 8E0971679G LOOM FOR GLOVE BOX a OBS35 3 10.16 30.48 15.02 8E0998521 RETROFIT K a OBS35 1 20.06 20.06 21.67
04-11-09, 03:36 PM | #7 |
8E1971029G HARNESS a OBS27 1 49.39 49.39 51.52 8E2721401AA CYLINDER a OBS35 1 29.3 29.3 40.6 8E2803357 RETAINER a OBS29 1 9.07 9.07 8.96 8E2803358 RETAINER T OBS29 1 6.29 6.29 6.22 8E2820021A FAN a VBBOX34 1 123.32 123.32 154.26 8E2820031 HEATER EXC a OBS25 1 68.31 68.31 75.12 8E2857131A26Z CATCH a OBS31 1 12.96 12.96 14.24 8E2959802 WINDOW LIFTER MOTOR a OBS30 1 105.35 105.35 121.88 8E5035225 BOOSTER)( a OBS19 3 10.16 30.48 11.01 8E5035225E BOOSTER a OBS36 1 22.49 22.49 24.3 8E5827249B BUFFER a OBS36 1 2.01 2.01 2.08 8E5827833 SECURING PLATE a OBS33 2 1.93 3.86 2.12 8E5833721C DOOR SEAL a OBS38 2 25.36 50.72 26.29 8E9827239A BUFFER a OBS20 1 9.29 9.29 12.62 8E9827339A01C COVER a OBS20 1 0.2 0.2 0.3 8E9955711A MOTOR a OBS22 1 37.53 37.53 43.19 8g0121285 AIR DUCT a OBS34 1 3.64 3.64 4.49 8g0121286 AIR DUCT a OBS34 1 3.97 3.97 4.49 8H0035411 LOUDSPEAK a OBS34 1 8.78 8.78 15.61 8H0601165B7ZJ WHEEL CAP a OBS25 4 10.54 42.16 9.88 8h0867738 BRACKET a OBS37 1 1.23 1.23 1.41 8H0871225A SOCKET a OBS25 2 1.73 3.46 4.73 8H0959747 SWITCH a OBS40 1 30.21 30.21 34.21 8H0959748 SWITCH a OBS23 1 22.5 22.5 34.21 8L071114101C GEARSTICK KNOB a OBS37 1 11.74 11.74 13.86 8L0803899B WHEEL BOLT a OBS16 2 6.66 13.32 8.27 8L0819045C AIR & HEATER CONTROL a OBS40 1 51.78 51.78 64.49 8L0820043BB98 CONTROL UNIT a OBS16 1 315.31 315.31 408 8L0823302B HINGE T OBS31 1 4.17 4.17 4.94 8L0823480B HOOK a OBS31 1 6.95 6.95 8.19 8L0823509C LOCK a OBS12 1 12.82 12.82 11.96 8L0823509G LOCK a OBS38 1 18.24 18.24 17.48 8L0837220NINB MAINKEY a OBS34 3 37.2 111.6 39.12 8L0837231A01C TRANSMITTER a OBS40 2 31.03 62.06 37.12 8L0857113A LOCK CYLINDER a OBS17 1 19.43 19.43 27.56 8L0857951N6PS ASHTRAY$ a OBS40 1 57.2 57.2 64.1 8L08579615FS ASHTRAY t OBS34 1 10.69 10.69 11.21 8l0862055a LOCK ZYL a VBBOX28 1 46.8 46.8 51.95 8L0863077B98 SHELF a OBS18 1 18.5 18.5 26.61 8L0863301F4PK LINING a OBS34 1 4.38 4.38 4.8 8L0863301H4PK INSERT a OBS34 1 4.55 4.55 4.98 8l08826271ej TRIM t OBS3 1 2.03 2.03 1.93 8l0919051h FUEL MODULE a OBS8 1 112.5 112.5 117.13 8L0919272C01C GAUGE a OBS6 1 35.44 35.44 47.15 8L0920950X CLUSTER * a OBS7 2 148.42 296.84 160 0 0 184.68 8L0920980DX A3 DASH POD * a OBS10 1 216.24 216.24 175 0 0 351.22 8l0920980mx COMB.INST. * a VBBOX22 1 204.65 204.65 175 0 0 351.22 8L0953503A01C WIPER SWITCH a OBS3 1 21.75 21.75 32.38 8L0953512A42R TRIM a OBS35 1 10.62 10.62 11.5 8l0955988a WASHER JET a OBS36 1 6.66 6.66 10.82 8L0959655C CONTROL UNIT a OBS9 1 233.45 233.45 241.07 8l0959753a01c REMOTE a OBS16 2 51.28 102.56 53.37 8L095985101C WINDOW SWITCH a OBS30 1 12.17 12.17 14.09 8L2035550 A3AERIALCA a OBS8 1 14.06 14.06 17.32 8L2857705V04 3 PTAUTO SEATBELT a VBBOX09 1 73.15 73.15 111.32 8L2858532J3FZ MIRRORMOUNTING a VBBOX34 1 39.63 39.63 47.18 8l2941531d SWITCH a VBBOX28 1 38.07 38.07 47.01 8L2941531F SWITCH a OBS14 1 37.3 37.3 47.01 8L30354202ET A3SPEAKERTRIMRHDR a OBS3 1 4.32 4.32 4.75 8L3857705CV04 SEAT BELT T OBS21 1 87.87 87.87 111.32 8L3857806BV04 BELT a OBS24 1 31.83 31.83 36.06 8l3881317b1ej TRIMPANELBLACK a OBS6 2 12 24 14.95 8L38813263PF TRIM PANEL a OBS37 1 13.15 13.15 14.2 8L38816337PE KNOB$ a OBS20 1 2.37 2.37 3.72 8L3882465A1EJ CAP TRIM T OBS14 1 3.34 3.34 3.66 8L3882465A2ET TRIM a OBS13 1 3.34 3.34 3.86 8l9133986b SET OF FUEL PIPES a VBBOX24 1 31.08 31.08 46.78 8L9915343 RETAINER a OBS34 3 5.2 15.6 6.15 8L9919051J FUEL UNIT a VBBOX27 1 109.94 109.94 115.39 8l9919673p SENDER a VBBOX20 1 36.3 36.3 39.61 8N0035420A5PG GRILL a OBS14 2 7.78 15.56 8.69 8N0103927B01C COVER a OBS21 3 38.16 114.48 25.85 8N0129604A INTAKE PIPE a OBS36 1 7.77 7.77 10.59 8N0199555C ENG MOUNTING a OBS37 1 73.22 73.22 78.64 8N0422804C TIE ROD z OBS39 1 48.75 48.75 51.01 8N0513025C SHOCK ABS T OBS17 1 47.13 47.13 29.4 8N0698151A BRAKEPADS t OBS31 1 43.08 43.08 33.98 8N0711141C05A KNOB a OBS24 1 37.53 37.53 51.69 8N0711141N23J KNOB a OBS29 1 90.13 90.13 100.78 8n0813327 MOUNTING a OBS34 1 1.64 1.64 1.72 8n0819045a01c CONTROLS a OBS39 1 122.07 122.07 136.26 8N0827505C LOCK a OBS31 1 34.34 34.34 34.96 8N0837434A WINDOW GUIDE a OBS12 1 19.98 19.98 27.58 8N0857536D MIRRORGLASS T OBS22 1 14.49 14.49 20.28 8N0953053 BULB HOLDER a OBS16 2 1.41 2.82 2.77 8N0955425 BLADE z OBS40 2 7.85 15.7 6.96 8N1837015B DOOR LOCK a OBS18 1 54.02 54.02 61.21 8N1920860JX COMB.INST. * a OBS14 1 255.99 255.99 145 0 0 400.49 8N2919910AX TT 160 COMBI UNIT * a OBS16 1 316.86 316.86 145 0 0 400.49 8n7035501a AERIAL a VBBOX24 1 42.33 42.33 42 8N7837031D RESERVOIR a OBS13 1 1.18 1.18 1.92 8N7837032C RESERVOIR a OBS13 1 1.18 1.18 1.62 8N78688854PK TRIM PANEL REAR a OBS7 1 27 27 38.08 8N7959802B LIFTRMOTOR a OBS16 1 62.37 62.37 71.28 8n7962267 CONTROL UNIT a VBBOX31 1 121.07 121.07 134.38 8N8051229A BRACKET z OBS24 1 18 18 18
04-11-09, 03:37 PM | #8 |
8N8857706G27D SEAT BELT a OBS15 1 66.22 66.22 111.32
8N8959802D O/S WINDOW MOTOR a OBS28 2 100.65 201.3 102.1 8P0051435AT SIEMENSC65CRADLE a OBS35 1 89.36 89.36 84.65 8P0051435M NOIKAAPT a OBS37 2 74.47 148.94 70.22 8P0805127 PLATE a OBS36 1 0.96 0.96 1.06 8P08633014PK INSERT a OBS32 1 0.72 0.72 0.93 8P08814804PK COVER a OBS28 1 3.44 3.44 3.99 8P30354358X5 GRILLE a OBS40 1 3.88 3.88 4.19 8P30354368X5 GRILLE a OBS40 1 3.88 3.88 4.19 8P3867667 STRAP a OBS40 1 6.86 6.86 7.45 8P3881633C7PE GRIP a OBS38 1 3.05 3.05 3.35 8Z0093109 FIRSTAID a OBS23 1 14.06 14.06 14.37 8Z0127401A FUELFILTER a OBS32 2 23.27 46.54 18.69 8Z0130314AC FUEL HOSE C OBS13 1 11.1 11.1 19.22 8Z0199167AG ENG.MOUNTI a OBS10 1 32.76 32.76 35.96 8Z0201795D CONTAINER a OBS22 1 34.09 34.09 45.58 8Z0711141P40 GEAR STICK KNOB a OBS17 1 11.84 11.84 21.59 8Z0711303P LEVER a OBS34 1 19.24 19.24 24.06 8Z0711874J CABLE a OBS34 1 51.33 51.33 52.74 8Z0801645A PLATE a OBS22 1 8.97 8.97 13.28 8Z0801645B PLATE a OBS23 1 9.4 9.4 14.02 8z0805110a SIDE MEMBER a VBBOX22 2 45.88 91.76 126.38 8Z0820043F5PR DISP.UNIT a VBBOX21 1 348.79 348.79 347.05 8Z0857805DV04 THREEPOIN a OBS27 1 42.81 42.81 68.01 8Z08632676PS SHELF a OBS28 1 5.17 5.17 10.11 8Z086710924S ESCUTCHEON a OBS6 1 0.3 0.3 0.4 8Z0898963 SET OF SECURING PART a OBS20 1 2.15 2.15 2.84 8Z0919183 FUEL GAUGE SENDER a OBS13 1 115.44 115.44 35.75 8Z0947111DEC3 INTERNAL LIGHT t OBS22 1 50.68 50.68 56.27 8Z0959643 AIR BAG T OBS39 2 51.39 102.78 47.37 8Z09598515PR SWITCH a OBS18 1 15.18 15.18 22.07 8Z0959855A5PR SWITCH a OBS19 1 5.58 5.58 8.33 8z0998998b KIT a VBBOX34 1 43.66 43.66 55.02 8Z2857535A MIRROR GLASS a OBS21 1 16.56 16.56 25.15 8Z2941531DB98 SWITCH a OBS11 1 33.75 33.75 50.9 8Z2959802A MOTOR a OBS33 1 91.19 91.19 104.77 905QHT028 HTLEADSET a OBS39 1 28.18 28.18 28.54 955VAG425C WIP SB 13 a OBS26 4 1.45 5.8 1.43 ASE44700501020 VAS 5095 a OBS29 1 368.04 368.04 451.84 D000703A1 ADHESIVE a OBS31 9 3.72 33.48 3.43 N01024016 BOLT a OBS38 9 0.18 1.62 0.12 N0115476 WASHER a OBS33 1 0.05 0.05 0.04 N0122981 CIRCLIP a OBS39 1 1.14 1.14 1.18 N0138494 WASHER z OBS22 1 0.21 0.21 0.12 N0138845 SCREW a OBS27 8 0.08 0.64 0.07 N0140963 SCREW a OBS6 8 0.23 1.84 0.05 N0160252 SCREW a OBS32 1 0.56 0.56 0.5 N0203535 HOSE t OBS31 1 2.05 2.05 3.63 N0438083 SEALING WASHER a OBS31 1 0.4 0.4 0.45 N10009104 BOLT HEX. HD. a OBS19 1 0.27 0.27 0.13 N10221801 HOSE T OBS11 20 12.05 241 8.65 N10243611 IGNITION LEAD a OBS33 1 10.66 10.66 10.62 N10311304 ISO BAND a OBS24 7 2.29 16.03 2.29 N10321001 SELF-LOCKING BOLT a OBS34 5 0.11 0.55 0.09 N10428101 BOLT HEX HD SHOULDER a OBS24 4 0.86 3.44 0.9 N90051201 BOLT a OBS4 1 0.63 0.63 0.59 N90422301 SEAL a OBS9 1 1.17 1.17 0.43 N90623001 TAPPINGSCREW a OBS27 9 0.12 1.08 0.12 N90707101 BOLT a OBS19 2 1.07 2.14 0.67 N90730601 PLUG a OBS27 2 3.25 6.5 2.64 N90772101 BOLT a OBS37 2 0.72 1.44 0.71 O28906461 AIR VOLUME METER a OBS26 1 125.11 125.11 144.13 O35103237 HOSE a OBS23 1 5.28 5.28 7.29 O38198243 STUD RETROFIT KIT* a OBS25 2 1.56 3.12 2.57 O48133154 POTENTIOMETER a OBS23 1 44.8 44.8 82.07 O48906265 LAMBDA PROBE a OBS30 1 51.78 51.78 56.11 O52121119 WATER FLANGE SEAL a OBS19 4 0.75 3 1.12 O59998998 KIT a OBS2 6 456.75 2,740.50 518.43 O77103385 SCREW t OBS10 10 2.06 20.6 1.4 O78133287 GASKET a OBS25 1 2.24 2.24 2.94 O89409069 SEAL a OBS35 4 0.43 1.72 0.41 OOOO71645 BRAKELTFORSPOILER a OBS19 1 29.92 29.92 29.58 OOOO71645 SPOILERLIGHT a OBS21 1 49.79 49.79 52.29 OOOO98680 AERIALWIRE a OBS30 4 8.04 32.16 8.25 WHT000001A NUT a OBS21 1 0.14 0.14 0.4 ZGB000503011 1L 50301 SLX T OILTOPUP 6 6.37 38.22 0 THE END !!!!!!!!!!!!!
04-11-09, 03:38 PM | #9 |
Rich, have chucked this in the parts for sale area and made it a sticky. There's bound to be a few useful parts there for people.
BTW, if anyone does a deal as a job lot on them, let me know and I'll unstick the thread else he could be getting phone calls forever and a day! |
04-11-09, 03:43 PM | #10 |
ok will do.
Thanks matey right folks..... looking at these numbers on here makes not much sense does it... but when I open the spread sheet page it shows how many in stock, and a price. PRICES ARE UP FOR NEGOTIATION SO ASK for a discount IF you want a copy sent to you pm me your email address and I'll forward it to you. Rich
Similar Threads | ||||
1986 audi 90 parts | jack1 | Parts Wanted | 4 | 04-02-10 11:55 PM |
NOS Audi parts | empi pervert | Parts For Sale | 0 | 26-07-09 02:51 PM |
Audi Genuine Parts Catalogue - Sheet Metal Parts | mjs4x4 | Parts For Sale | 0 | 13-06-09 07:10 PM |
1974 Audi 80 parts | blunty | Parts Wanted | 12 | 29-11-08 08:05 AM |
Input shaft oil seal ? obsolete ? | wayno | Suspension & Brakes | 15 | 28-03-08 10:23 AM |
