Members: 13,472 | Total Threads: 40,056 | Total Posts: 470,823 Currently Active Users: 409 (1 members and 408 guests) Welcome to our newest member, uoqumcva |
08-11-18, 08:47 PM | #21 | |
08-11-18, 08:50 PM | #22 | |
I only see the standard choice of pipe work on Vipers page, but interested in this custom correct end information. Thank you JAM |
08-11-18, 09:08 PM | #23 |
so the part number for 22 is...
N0203001 11X3,5 supplied in 5m rolls (originally) shorten to 240mm. VW heritage supply this... https://www.vwheritage.com/n0203001-...meter-vw-spare Clamps are: N10258201 12-22X9X0,4 12mm to 255mm bore, 9mm wide band, .4mm thickness of band Again Heritage- https://www.vwheritage.com/n10258201...-25mm-vw-spare Is that what you have on the car? You initial post was talking about crimped joints? |
08-11-18, 09:12 PM | #24 | ||
03-12-18, 07:02 PM | #25 |
So I found my problem, it was quite simple! It was just me...
I simply tightened up all the fixings & the issue was solved, but then noticed a smaller leak around the washers at the neck of the banjo fitting. I removed the fuel filter again to tighten & replace the washers, then f__ked the fuel filter & snapped the banjo fitting Waiting on new parts & still looking for a replacement banjo fitting. Just call me Frank Spencer, because some mothers do have them! You live & you learn |
04-12-18, 09:08 PM | #26 |
Sometimes we make our minds up about a problem before we really explore all the options and thus get stuck. I am murder for it.
Hope you get it fixed soon.. |
