Members: 13,623 | Total Threads: 40,056 | Total Posts: 470,826 Currently Active Users: 816 (18 members and 798 guests) Welcome to our newest member, adewamu |
17-06-14, 06:22 PM | #1 | |
Girling G60 fitting problem - pics inside
Okay, after finally reaching the point where i put the B3 suspension back on my coupe GT all was going quite smoothly until i tried fitting the brake disc.
The brake discs are Zimmerman discs, dia 276 mm - 25 mm thick With the brake disc fitted to the hub it then is not perfectly aligned with the center space of the brake caliper holders. This problem could be overcome by simply adding some spacers in between the brake caliper holders and the hub mounting points. This is the brake disc: This is the hub: This is the disc fitted to the hub + the brake caliper holders This is the current situation: So i simply add spacers accordingly at the red arrows to align the brake caliper holder with the disc? |
17-06-14, 06:28 PM | #2 |
17-06-14, 06:38 PM | #3 |
“Been raced and rallied”
Have you fitted the brake pad's yet ? look's a bit of centre in the pic.
Vorspurng durch Technik (see it does work) |
17-06-14, 06:40 PM | #4 |
what are the hubs from and what are the discs for.
There are different versions of discs and hubs for saloons and Coupes - they cannot be mixed or you get the problem you're seeing
17-06-14, 07:02 PM | #5 |
Looks like you have the wrong discs.. They're available in 51mm and 56mm height...
1985 Type 81 2 door 2.8 V6 1983 Golf GTI track weapon 1977 Scirocco G60 1968 Sand Rail 2006 A4 2.0 TDI Avant = DEAD due to oil pump failure.. then alive.. then DEAD due to cam belt tensioner failure! and ALIVE again!!! Last edited by Addicted; 18-06-14 at 10:30 AM. |
17-06-14, 07:40 PM | #6 |
Fitting the pads is of no use as the disc is thoughing the brake caliper holder if i were to screw it down.
The hubs are of a B3 - the discs are for a B3 but i wasen't aware there were two versions. I bought the hubs of a guy with a massive amount of Audi parts - so i wasen't told from what type of B3 they came. So rather then trying to sell these and scoursing the other one i'm simply going to add spacers. Last edited by McLarenboy; 17-06-14 at 07:46 PM. |
18-06-14, 07:21 AM | #7 |
18-06-14, 10:19 AM | #8 |
You'll need longer wheel bolts too
For safety, personally I wouldn't use spacers behind the disks. Disks are cheap enough these days.... |
18-06-14, 10:28 AM | #9 | |
Is the 51mm offset disc the uber expensive one?
1985 Type 81 2 door 2.8 V6 1983 Golf GTI track weapon 1977 Scirocco G60 1968 Sand Rail 2006 A4 2.0 TDI Avant = DEAD due to oil pump failure.. then alive.. then DEAD due to cam belt tensioner failure! and ALIVE again!!! |
18-06-14, 11:48 AM | #10 |
The 51mm disc is the 90 20v disc and less common so more expensive
