Classic Audi Ľ Technical Ľ Mech/Tech Ľ Electrical problems » 2bar boost reading and odd fuel gauge behaviour.
Old 07-01-19, 02:58 PM   #1
Default 2bar boost reading and odd fuel gauge behaviour.
Iíve a curious fault with the Ur since its return from restoration and Iíve spent several hours going through wiring diagrams and the car to no avail.
The core symptom is -
With ignition switch live, boost gauge reads 2bar and fuel gauge reads about 6 gallons low.
With the ignition switch dead (key on but immobilised) it is fine.
With ECU disconnected, itís fine.
Car runs fine in every other respect.
Has anyone experienced similar or knows any pointers?
All thoughts greatfully received.
1985 WR quattro, 1985 20vT RallyRep, 1993 MTM ABY S2 Avant.
Isimmo is online now   Reply With Quote
Old 07-01-19, 04:29 PM   #2
lefthooker
Sounds like the sort of problem you sometimes get with a faulty earth.
Old 07-01-19, 06:35 PM   #3
4v6
The engine meister!
Thinking same thing.
Since its all been apart its likely somethings not connected or contacting when it should.
Old 08-01-19, 10:23 AM   #4
Hanuman
Hanuman's Avatar
Havenít you also just had a new alarm system installed? But Iíd certainly be looking at earthing issues.
Old 08-01-19, 05:55 PM   #5
Hi folk
Thanks for the replies so far.��
The alarm is new but was fitted after the fault materialised it would appear. There was a bit of a panic that the car was very low on fuel before it was MOT'd and that was before the alarm was fitted. It subsequently turns out that the car only took 10 gallons to brim the tank, not 20.
