Classic Audi Technical Mech/Tech Suspension & Brakes » Removing Front Hub
Old 06-12-17, 04:51 PM   #1
Rosco
Rosco's Avatar
Default Removing Front Hub
Hi Forum, I am trying to remove the front hubs from my Audi Coupe quattro (b2).
I've got the correct socket size for it, but the hub is just spinning.
How do I stop the hub and driveshafts from spinning? Should I have loosened the bolt while the brakes were on?
Thanks
Rosco is offline   Reply With Quote
Old 06-12-17, 05:49 PM   #2
vorsprung durch technik
You should have loosened the bolt when the wheel was still on and on the deck. Will easily crack off with a nice long extension bar.
Old 06-12-17, 05:51 PM   #3
Rosco
Rosco's Avatar
Thank you, thought this might have been the case!
Old 06-12-17, 05:52 PM   #4
Old 06-12-17, 06:04 PM   #5
sinbin5t
sinbin5t's Avatar
Easy mistake first time, we all do some crackers.
Old 06-12-17, 06:08 PM   #6
Have i done it before, yeeees.
We're enthusiasts as apposed to time trained and served mechanics.
Old 06-12-17, 06:09 PM   #7
sinbin5t
sinbin5t's Avatar
Old 06-12-17, 09:24 PM   #8
buzzin
buzzin's Avatar
You can put 2 wheel studs in and use a wheel brace or breaker bar type object to stop it rotating while you undo the hub nut.
Saves putting the wheel back on, lowering the car etc
buzzin is offline   Reply With Quote
Old 07-12-17, 07:12 AM   #9
Colin Aitchison
Colin Aitchison's Avatar
Buzzin, Been there done that, one thing is for sure, if you are going to work on your own car you are at some point going to f**k up, take it on the chin and accept it, it is still way better than putting it in to a garage and they f**k up and bill you for it.
Old 08-12-17, 09:53 AM   #10
Nikola
Nikola's Avatar
Lol, true
Nikola is offline   Reply With Quote
