Classic Audi Technical Mech/Tech Suspension & Brakes » Help i'm struggling on this.
Old 01-11-17, 01:58 PM   #11
Davids
Yep been using plusgas formula A.
My tin of eBay has already lost it's pressure after only been used a couple times.
So did it work ok ?
Davids is online now   Reply With Quote
Old 01-11-17, 02:06 PM   #12
vorsprung durch technik
Originally Posted by Davids View Post
So did it work ok ?
Ive sprayed it on both sides aplenty and and left it for now to soak in. In the meantime have washed and clayed all 4 wheels and polished them up with a super duper polish that resists brakes dust. Been fishing monday but hoping to get back on it tomorrow.
Personally i don't think any amount of plusgas is going to help. Reason,..........all my brake lines are coated in PVC and if they start to powder up underneath no amount plus gas is going to help whilst the pvc is still there. I'm faced with carefully and laboriously cutting back the pvc sheath and clean up as much as possible and then give it another go. I'll provide pics later of this as it's obviously a problem for these cars.
Old 01-11-17, 02:21 PM   #13
Davids
Never used it myself but lots swear by a 50/50 mix of ATF and Acetone.
Loads of stuff on the net about this and looking at some of the actual test it seems to work.
Wouldn't take much to steal the wife's nail polish remover and get some power steering fluid etc and give it a go.
Old 01-11-17, 02:33 PM   #14
Good shout,didn't think of that although have heard of it. Cheers,if the other fails i give it a try
Old 01-11-17, 05:58 PM   #15
SwallownAmazon
SwallownAmazon's Avatar
ATF and Acetone.
Thinners a lot cheaper than nail polish remover - the solvent is just a carrier for the ATF and thinners (ethyl acetate/acetone/toluene) should be just as effective.
Best of luck but I find Formula A will work in the end. Perseverence dear boy!
When it's all going back together, a good spray with a lanolin based anti-corrosive and regular treatment afterwards will help. This stuff is the dog's...
http://www.fluid-film.com/
Old 01-11-17, 11:04 PM   #16
Alburglar
Alburglar's Avatar
I vote heat too. I use one of these cheap blow torches / Cooks torch. It does most jobs. Probably available cheaper if you search t'internet.
https://www.amazon.co.uk/gp/aw/d/B00...jZL&ref=plSrch
...plus I agree that a brake spanner is a must, I'd use one on both sides tho, if you have a pair the right size.
Alburglar is offline   Reply With Quote
Old 01-11-17, 11:06 PM   #17
Alburglar
Alburglar's Avatar
I use acetone to clean fibreglass resin off my tools. It is bloody good stuff, never heard of the ATF mix before, but It sounds promising.
Old 02-11-17, 05:25 PM   #18
Perseverence, i'm usually not too bad at that but when i'm on my back straining my neck i get a little
Thanks for the advice on the productsomething on the to buy list now.
Old 02-11-17, 05:30 PM   #19
I'm going to take you up on that idea, my usual pro plumbers torch is way to powerful for this so thanks for the heads up on the cooks torch.
You would think my brake spanner of 25 years would be useful.Absolutely not in this case! Getting more luck out of a 11M open ended spanner except on the really bad side where the small mole grips is in order.
Old 02-11-17, 05:37 PM   #20
Well i've been having fun out there. I've got the passenger side done now, leaving the plus gas these last few days to work and removing the pvc sheathing has worked.
Once the pvc sheeting was removed and the effects of Plus gas A i was able to ease of nut sufficiently to use it as intended. Phew! All done now on that side.
