Members: 13,490 | Total Threads: 40,056 | Total Posts: 470,823 Currently Active Users: 645 (21 members and 624 guests) Welcome to our newest member, uawizofbor |
16-03-18, 11:23 AM | #1 | |
Smart Alternators
Peeps,
I was chatting to a mate of mine about an on-going problem he's been having with his battery. He's been told by his dealer (Alfa Romeo) that these new 'Smart' alternators only charge when there is no input from the accelerator. i.e., they only charge when idling or coasting, so there'is a strong possibility one's battery never gets well charged.... Has anyone else heard this? |
16-03-18, 12:06 PM | #2 |
I understood it was part of the fuel saving benefits of the 'coasting' mode of some current vehicles.
16-03-18, 12:38 PM | #3 |
Been common-place for a while now.....if you're belting along at 70 mph with no extra consumables switched on....does the battery need charging, no.
Alternator will start charging it again when voltage drops below a prescribed amount. Yet another ECU on the modern car |
16-03-18, 03:06 PM | #4 |
I had a 2008 BMW that only charged when coasting or braking, all to do with MPG saving.
16-03-18, 05:07 PM | #5 |
Seems more of a threat to reliability
16-03-18, 08:42 PM | #6 |
That's not alternator but charge controller, separate control unit that controls charging of the battery. Dunno which was first B series audi to have it, B6 or B7, in C series first was C6. It also requires that battery intended for that to be bough, with some specific code, which is used when adapting new battery to controller - if old battery will be replaced by new one without adaptation, controller won't charge it fully...
16-03-18, 09:01 PM | #7 | |
Makes me glad to drive the older stuff, better for the environment too |
17-03-18, 12:50 AM | #8 | |
17-03-18, 06:49 AM | #9 | |
On the negative terminal* (if it has smart charging) there is a sensor which tells the ECU how many amps the battery is taking. Only if it is fully charged (and in good condition- the ECU will decide) and therefor taking very little charge, will the car be running solely off the battery. The above is my take on it, TBH I'm not really worried about how it works just as long as it stays working! *A cover on the negative terminal with picture showing not to attach a jump lead is a sign that it has smart charging. |
17-03-18, 11:16 AM | #10 |
That explains why my E38 BMW 740 Sport has jump lead terminals under the bonnet when the battery is in the boot and not easy to get at. I'll start a thread on the 7 Series forum and find out some more as my alternator seems to be working overtime with the characteristic whistle as though it's working hard. That'll be a bugger if it ever goes wrong - it's buried deep in the front of the V of the engine as it's cooled by water at around 88 dec C. How hot can the bloody thing get ?!?
