Members: 13,554 | Total Threads: 40,056 | Total Posts: 470,824 Currently Active Users: 755 (21 members and 734 guests) Welcome to our newest member, ivejatere |
24-01-19, 07:01 PM | #1 | |
jogi
7A rear hub carriers wanted
Hi all,
Have been collecting parts slowly to change some of my running gear. So far I have: Front hub carriers - secured Front hubs - secured Front uprights - secured Front drive shafts - secured Rear uprights - secured Rear hubs - secured Rear drive shafts - secured Rear differential - secured So still needed are a pair of rear hub carriers. Can anyone help me out please?
1985 Audi 90 quattro 20v turbo with some tweaks Last edited by jogi730; 26-01-19 at 10:11 AM. |
24-01-19, 09:34 PM | #2 |
Whats brought about the changes Chris!
24-01-19, 10:05 PM | #3 |
jogi
Change of gearbox Will be running 03A so needed to change front driveshafts. These are quite a bit beefier/stronger and should cope with the power better
I hope to write an update with pics soon
26-01-19, 10:07 AM | #4 |
jogi
Bump!
1985 Audi 90 quattro 20v turbo with some tweaks Last edited by jogi730; 26-01-19 at 10:12 AM. |
27-01-19, 07:38 PM | #5 | |
Interesting choice of box..... Will it fit as well as the CGR S2 version?
27-01-19, 08:23 PM | #6 |
jogi
It is indeed B7 RS4 box. I was having some problems with the conversion kit Patrick supplied me. I think the most likely cause was the quick shift I was running. Patrick had to guess differences to make it work. Was never quite right, but final straw was the selector rod breaking. Had to drive all the way to Mark with only 3rd and 4th gears
The ratios are quite short apparently, 80mph should be around 3200-3400RPM . Much better suited to quick sprints than the diesel box I was running. Also a much nicer box to use from what I have been told. hence all the changes. Error_404 on S2 forum does a kit to enable the swap.
05-02-19, 06:53 AM | #7 |
jogi
Hubs now found
12-03-19, 04:47 PM | #8 |
jogi
Someone has kindly lent me a pair so I can move forward with my project.
However, I am still looking for a pair as I need to replace them. Someone must have a pair please?
13-04-19, 11:19 PM | #9 |
jogi
I'm still in need of these please folks!
