Members: 13,710 | Total Threads: 40,056 | Total Posts: 470,826 Currently Active Users: 696 (20 members and 676 guests) Welcome to our newest member, tadalafil 20 mg |
23-06-10, 11:21 PM | #21 |
Banned
[quote=Audiden;141978]This thread makes me think I should do the cambelt change on my 90 20v myself, rather than letting the local garage have a go at it... Torque wrenches of the required force seem rather expensive though.[quote]
Some years ago our US friends used to organise timing-belt-a-thons. Yeah - you need a crank locking tool and a monster torque wrench - but only for seconds. Getting in there and getting out again takes the time - if there are ten of you, the outlay to bring in the gear is peanuts and sharing it is not an issue. Organise it here - I'm sure the mods will provide necessary support. |
23-06-10, 11:37 PM | #22 |
Black Coupe Collector
As if by magic Phil Payne appears....
Its all gone a bit Mr Ben
95 UrS6 87 Coupe Quattro |
24-06-10, 08:06 AM | #23 |
thanks
Thanks for all the info and advice. I'm hoping I'll have some good news to post soon....
24-06-10, 08:16 AM | #24 | |||||
A pleasure!
Here's what Loctite say about Loctite Blue: Quote:
Paul |
30-06-10, 07:00 AM | #25 |
It's running....
£1245 lighter of pocket. 9 valves replaced plus all the usual stuff associated with having had head, inlet man, turbo etc off. Will post parts prices later (all from TPS I believe) for those of you contemplating timing belt changes. Only problem I noticed is boost gauge permanently reading 1.0 and car seems a little slower (might just be me) - is this likely to be something simple eg line to ecu not replaced or something I should give it back them for? Don't really want the car back in the shop again if I can avoid it. |
30-06-10, 09:55 AM | #26 | |
Good news - another one back on the road
30-06-10, 05:33 PM | #27 | |
Next question - the fan seems to be running continously from cold start - is this possibly due to the high ambient temps in the UK (computer reading 26 degrees) or is there a temperature sensor not wired? Both water temp sensors were replaced during the engine rebuild... |
30-06-10, 07:00 PM | #28 |
COULD THE SQEEKING/CHIRPING NOISE FROM THE FRONT OF GODZILLA RELATE TO THIS FAILURE?????????????
Tags |
aan, crank pulley, timing belt |
