Members: 13,531 | Total Threads: 40,056 | Total Posts: 470,823 Currently Active Users: 736 (23 members and 713 guests) Welcome to our newest member, odagobaveca |
13-03-16, 09:17 PM | #11 |
14-03-16, 07:19 AM | #12 |
Just a little tip here
Do not buy a diff off a b4 car(saloon/avant),coupes are different, this has caught out at least 2 people (possibly on this forum) I know of. |
14-03-16, 08:26 PM | #13 |
Would b2 coupe fit? No ARB mounts though
14-03-16, 08:50 PM | #14 |
2.8 coupe diff is different ratio to 5 cylinder cars so diffs are not that common, I believe they are 3.89 as opposed to 4.11 so it may involve a gearbox/diff change from a 5 cylinder car if you can't locate one, although I believe the B5 A4 cars use the 3.89 ratio as do some of the bigger quattro autos in the A6 range (needs an expert to confirm) I know that when my dad broke his gearbox in his 10v B3 90 quattro I swapped in a replacement box and diff from a 2.8 coupe and it buggered his acceleration as the ratio is longer (as in lowers the revs in all gears)
When I finally get my 2.8 coupe quattro back together it will have an S2 box/diff ratio so it will rev higher at any given speed |
14-03-16, 09:27 PM | #15 |
Ragtop Collector
I have a good condition diff taken from a running 2.8 coupe if you are interested.
I'm in Chorley Lancashire. Andy
"Earl" 1998 2.8 V6 Cabriolet "The Duke" 1997 2.6 V6 Cabriolet (Sold....sadly) Project "Best of Both Worlds" 1995 S2 Quattro Cabriolet |
17-03-16, 12:08 AM | #16 |
Thanks for your comments and suggestions so far guys, I really appreciate your input here.
With all good intentions, with family and work commitments I have had to throw in the towel of DIY and get someone to look at this for me. The mechanic basically said there is some good and bad news... Good News It looks like the Diff is ok, its the OSR CV joint that's gone. An OEM Rear Outer CV Joint kit is available. He is getting me a price for an after market Rear Outer CV Joint kit tomorrow. Bad News If the male cog (not sure what the correct name is) on the end of the drive shaft has sheared which he said is most likely rather than the female part of the joint, Then I'll need a new drive shaft. He won't know until he takes it apart. There is also a fluid leak on the rear diff. I may be in the market for a CQ 2.8 rear drive shaft if anyone knows where one is lurking? @andydunn2 I am interested in hearing a bit more about that diff? Is there a Drive shaft or 2 along with it? |
17-03-16, 07:12 AM | #17 | |
.......has he actually done any more than what you've done to diagnose the fault!!! |
17-03-16, 08:51 AM | #18 |
If the splines on the driveshaft have worn then youll likely need an outer cv joint ( not too bad to do) and the hub itself which is more trouble due to you needing to put a new bearing in at the same time as theyre pressed in pretty darn tightly.
17-03-16, 04:47 PM | #19 | ||
He has come back to me and the Splines have failed and sheared off and I need another OSR Drive shaft!! Does anyone know whether an s2, 20v, 80/90 Quattro rear drive shafts will fit my 2.8? Cheers |
17-03-16, 09:19 PM | #20 |
Well, that doesn't matter here - B5 uses similar rear diff like B4 avant/saloon, apart from lacking lock, and C5 rear diff is also different.
