Classic Audi Technical Technical Info » Coolant
Old 07-10-19, 09:39 AM   #1
BackintheFold
Default Coolant
Just a heads up...
I bought some AFG13 coolant from ebay, on the basis it was G13 specification. The bottle has NO information on it as to the specification.
The liquid inside is green.
Apparently it is not G13 spec....
Now I found that extraordinary, but maybe I'm an idiot...
Yes, I know green antifreeze is not G13.
I think green is G11
(EDIT: as per MikeS, G11 is normally blue, and I now read several sites saying "green-blue")
, but then again I can add colourant to petrol and make it green, it still isn't G11. My point is that it is HUGELY misleading to market AntiFreeze as AFG13 that is not G13 spec.
(G13 spec mixes with all previous antifreeze specs. If you mix the wrong types together they form a gel in the engine. I bought this stuff to refill a flushed out system, so I am ok, but I wanted tot use the extra to top up some other systems....now I can not!)
EDIT bottom line, don't mix G12 with G11. For the cost, its probably safest to drain the lot, flush and refill with whatever you want.
Don't leave Antifreeze lying around, it is poisonous to cats but they like the taste.
Old 07-10-19, 10:57 AM   #2
G11 is normally blue. It's what I've been using in both 90s.
G13 is a pink colour.
You can mix G13 with G12+, G12++ and G11.
Don't mix with G12 (red)
1988 90 quattro 2.6
mikes2 is online now   Reply With Quote
Old 09-10-19, 10:58 AM   #3
BackintheFold
by extraordinary co-incidence, I stripped a bike down yesterday to replace the water pump, and found a whole heap of gunge formed in the cooling system from mixing antifreeze types, so I can confirm that this is a "real thing"
Yuck. Hose pipe flushing on the way!
Old 10-10-19, 09:46 PM   #4
you normally get brown sand like sludge when G11 and G12 are mixed
1988 90 quattro 2.6
Old 01-03-20, 11:57 PM   #5
Gaz
Gaz's Avatar
I cringe in winter when customers come in buying engine coolant.
I try to explain to them the importance of knowing what is already in their cars and what will happen if they mix the wrong types.
Some of them take on an "it'll be alright" or "its an old car it doesn't matter" attitude.
