Classic Audi Technical Mech/Tech Bodywork, glass & exterior fitments » Door Handle removal
Old 13-11-17, 03:01 PM   #1
hotsnot
Default Door Handle removal
So my drivers door handle exploded last week on my B2 Coupe, new one on its way. Whilst investigating what had happened I found it impossible to remove the rod for the locking mechanism from the handle/door lock. Any advice on how this is achieved would be appreciated, the door latch release was dead easy.
Jase
hotsnot is offline   Reply With Quote
Old 13-11-17, 05:28 PM   #2
4v6
The engine meister!
Youll need to remove the door card to access all the bits as the locking rod is on a plastic clip that has to be rotated around and off the rods to get the handle out the door.
Haynes manual is a good source of info for these models as theyre detailed, unlike all their newer stuff which is written for nursery grade mechanics...
Old 14-11-17, 12:55 PM   #3
hotsnot
The haynes manual I've got seem to cover s2 door handle removal but not b2. I had a go last week and there didn't seem to be enough movement in the rod to get it to clear the plastic bit on the lock/latch mechanism. I don't want to get to ham fisted with it and break something else.
Old 14-11-17, 02:37 PM   #4
Here's a handy youtube guide....
https://m.youtube.com/watch?v=7_PX1cVuaVA
1985 WR quattro, 1985 20vT RallyRep, 1993 MTM ABY S2 Avant.
Old 14-11-17, 03:14 PM   #5
vorsprung durch technik
On a serious not Jase, get yourself an old copy of the B2 saloon coupe Haynes manual.
Old 15-11-17, 12:06 PM   #6
hotsnot
Hopefully this will be the right one.
https://www.amazon.co.uk/gp/product/...?ie=UTF8&psc=1
Old 15-11-17, 01:49 PM   #7
Hanuman
Hanuman's Avatar
Depending upon which rod is involved-
Some are retained in plastic collar; once inserted, the collar is rotated and clips around the rod, holding it in place.
Others go together in a sequence. Item 9 I think is disconnected from the latching mech first (1&7), once the rod is dangling in the 'quadrant' item 29, the rod is turned through 90, and simply slips out of the slot.
What you really need to do is show a pic of the problem bits, so that specific suggestions can be given.
enjoying Fish amok and a draught Angkor
Old 15-11-17, 01:54 PM   #8
Yes that's the right one.
Old 15-11-17, 02:19 PM   #9
hotsnot
Cool cheers, it's part 9 I am having problems with , I can't get it detached from the latch mech.
Old 19-11-17, 06:54 PM   #10
hotsnot
Well that was a waste of 2 hours, couldn't get the old barrel into the new handle, all the levers fell out of the barrel that came with the new handle, the handle is a shit fit, old seals don't fit, had to tap the end where its screwed to the door and to top it all it won't open the door so I'm still having to open it from passengers side .
Has anyone bought and used one of the door handles from vw heritage or classic vw?
