Members: 13,757 | Total Threads: 40,056 | Total Posts: 470,826 Currently Active Users: 609 (18 members and 591 guests) Welcome to our newest member, urasofebelux |
30-09-11, 12:06 PM | #1 | |
Audi 100 Central locking
I guess this is the right section as its not electrical or exterior.
Basically the central locking to the boot has stopped working, ive had a look all around the boot, taken off the black plastic panel but cant seem to find an obvious fault. Could anyone tell me the best thing to do before i start dismantling the whole thing. Cheers Andy |
30-09-11, 12:13 PM | #2 |
Are you hearing any strange noises as the CL tries to work?
I assume the doors are operating as they should and if you are hearing no strange noises when you activate the system I would assume you may have an air leak somewher, as the C3 has a pneumatic system for the central locking. If you were hearing funny noises, I'd suggest checking the CL pump, usually located under the rear passenger seats or in a corner of the boot. |
30-09-11, 01:25 PM | #3 |
No strange noises, the 4 doors are fine, its just the boot that wont operate with the central locking, works with the key.
How do i go about sorting this dude, will it be fairly straight forward? cheers |
30-09-11, 01:45 PM | #4 |
I've no experience with saloons, but I guess you will have to strip down the relevant bits of your interior and check what condition the connections/pipes are in, from the boot back to the pump. Put an hour or so aside for this.
If you find no air leak, all I can suggest is a faulty component at the boot end. be absolutely sure the pump us pumping to the boot, and not just the doors. My pump was the culprit on the day and I was lucky enough to find a spare at the scrappy. That was 10 years ago! Regarding your post about suspension pressure spheres, they are found on Avants only. Count your blessings....................................:wall : |
30-09-11, 01:56 PM | #5 |
cheers dude, appreciate your help.
hope your prob isnt to costly |
