Members: 13,471 | Total Threads: 40,056 | Total Posts: 470,823 Currently Active Users: 211 (0 members and 211 guests) Welcome to our newest member, edepcufu |
09-06-20, 03:02 PM | #11 | |
Do you mean t89 2 bolt front wishbones or t85 ? thanks steve
09-06-20, 06:08 PM | #12 |
You can use Irwin grip sockets to get the allen bolts off if they are rounded.
Either T85 or t89 - you just need to ensure they're not off set. T89 is probably best as they often don't have the bush for a drop link
10-06-20, 07:58 PM | #13 | |
https://www.ebay.co.uk/itm/TRACK-CON...3fb39ad2d4a6ab
10-06-20, 10:17 PM | #14 |
Yep - they'll work, although you can get the other type which don't have fittings for the drop link bush
11-06-20, 01:53 PM | #15 |
having checked in then garage now it's not raining that's the ones it has fitted
[IMG]wishbone by S Datus, on Flickr[/IMG]
11-06-20, 03:34 PM | #16 |
It seems these wishbones are going at a good price now, just checking out the front ones, 3 bolt mounting for the swivel on a 1989 coupe quattro parts numbers 895 407 147A & 148A I think are the part numbers ? £45.99 for a pair delivered :-)
I have cleaned the old front ones up but for that price I might as well replace them
11-06-20, 03:51 PM | #17 |
you sure your 89 has 3 bolt fixings ?
They didn't start until L chassis cars which is 1990 MY
11-06-20, 04:00 PM | #18 |
99% sure it has, I will need to go and check now.....
Checked they have the 3 bolts, I did take a picture but virgin media up load speed means its failing to upload to the www of flikr (less than 1mbps at the moment ) and finally after 1 1/2 hrs [IMG]wishbone front by S Datus, on Flickr[/IMG]
[FONT] '76 Leyland Princess 2200 HLS '79 Scirocco storm '84 WR '89 coupe quattro '01 A2 1.4 TDI SE '14 A3 1.4 TFSI COD [/color][/size][/font] Last edited by steveb; 11-06-20 at 06:28 PM. |
22-06-20, 09:18 AM | #19 |
Some progress, stubborn rear diff. mounting bolt removed, which has allowed the subframe to be removed
[IMG]Diff mounting by S Datus, on Flickr[/IMG] [IMG]Diff mount by S Datus, on Flickr[/IMG] [IMG]Subframe by S Datus, on Flickr[/IMG] [IMG]Old mounting by S Datus, on Flickr[/IMG]
