Members: 13,535 | Total Threads: 40,056 | Total Posts: 470,823 Currently Active Users: 748 (22 members and 726 guests) Welcome to our newest member, sixoweo |
13-01-08, 01:38 PM | #1 | |
==>PUGSPORT!<==
WR UR quattro engine + components
Due to impending 20vTurbo route and rebuild the WR engine i've removed is being split for parts... Its already stripped down and inspected.
The engine had done 123,541miles according to odometer on the digidash and i only had problems with turbo and blowing manifold (suprised?). I can get stuff checked at my local machine shop when i drop various 20v parts off for cleaning and inspection but i'll see how much they want to charge me if they aren't feeling kind like they were last time. WR 10v turbo 2144cc Crankshaft. Journals all fine no signs of scratching/marking from foreign bodies in the oil or overheating. Crank Comes with pulley bolt but no pulley/mains caps etc. This could be very useful if you have a damaged crank and don't want to fork out for a replacement engine or try and get hold of a new replacement. I can get more photos on request. £150 WR 10v Turbo 2144cc Pistons + Conrods. These are all fine, I have removed circlips so i could remove gudgeon pins but these will be included (providing i relocate the box i put them in). Journals on the Conrods appear fine, all bearings looked good when i removed them. May be good for someone. Piston size is 79.495mm stamped. Gudgeon pin is 22mm £100 for the full set of 5. Bare Inlet manifold. The inlet manifold is bare without Throttle body or cold start injector etc. Not much more to say about ir really. £20 Standard Wastegates x2. I have 2 standard WR wastegates, note will not come with the concertina pipe section. AFAIK both have standard springs but i can check this. £20each. Will also have bare head, block, valves, camshaft, inlet manifold, and various other parts available, but i want to get block checked for ovalling first before listing. Head has usual small cracks between the valve seats due to heat transfer and also one of two sheared studs (exhaust manifold). I haven't had a chance yet to go through alot of the bits but most stuff engine wise will be available. Finally.... My digital Dash will be forsale due to me going for analogue dials when the car is finished. The Green digital dash worked fine incar and i have included a few photos of it. Due to its rare nature and the fact they don't come up very often i'm open to offers as close to £200. |
01-07-17, 02:20 PM | #2 |
Dashboard
Do you sell the dashboard? Please contact to me in PM
01-07-17, 03:23 PM | #3 |
02-07-17, 10:37 PM | #4 |
Do you have one?
02-07-17, 11:59 PM | #5 |
03-07-17, 05:36 AM | #6 |
I'm looking for one and I do not want to let anything go wrong!
Similar Threads | ||||
kv quattro engine mounts | audicoupeparts | Parts Wanted | 0 | 29-06-09 08:26 PM |
complete right hand rear brake drum and components | tommyboy | Parts Wanted | 1 | 28-06-09 12:06 PM |
1B Engine (same as MB ur quattro) | steveb | Engine | 5 | 22-04-09 10:06 PM |
UR quattro ecu (for wr engine) for sale. | Jenks | Parts For Sale | 1 | 15-02-09 03:14 PM |
coupe quattro 2.2 KV engine | Derek | Engine | 4 | 02-02-09 10:27 AM |
