Members: 13,650 | Total Threads: 40,056 | Total Posts: 470,826 Currently Active Users: 788 (18 members and 770 guests) Welcome to our newest member, adejecayedocu |
09-12-17, 12:38 PM | #1 | |
Central locking pump location for Audi 80 Cabriolet
Hi,
I removed all the panels in the trunk this morning in search of the central locking pump to install a remote receiver. I could not locate it... anyone who happens to know where it might be in a Cabriolet? Thanks for the help! |
09-12-17, 01:15 PM | #2 |
its either under the back seat or more likely behind the trim panel next to it on the passenger side on a lhd car
09-12-17, 01:20 PM | #3 |
09-12-17, 03:45 PM | #4 |
Ok, I was able to remove the bottom cushion of the rear seat, but how do you remove the top cushion???? There are 2 screw in the bottom but top is stuck and I don't find where it is attached...
09-12-17, 05:13 PM | #5 |
Ok it's on the right side according to this drawing:
https://epc.realoem.com/cat_spares/e...aca/40/862000/ Now how do I get in there how do I remove the back rest of the back seat? |
09-12-17, 10:31 PM | #6 |
The back seat of my B3 is retained at the bottom by a couple of "bendable" tabs that hook through thick wire lugs in the upholstery. I had to bend these tabs to release the wire lugs and then push the seat back upwards to release it from two hooks in the bodyshell. I wouldn't think the B4 would be significantly different.
10-12-17, 08:53 AM | #7 |
Yes found the damn thing it is on the right side behind the side trim... finally...
