Members: 13,710 | Total Threads: 40,056 | Total Posts: 470,826 Currently Active Users: 701 (21 members and 680 guests) Welcome to our newest member, tadalafil 20 mg |
02-03-17, 12:29 PM | #1 | |
Ur quattro Fuel Injector Seals
Hi all,
Any advice on changing the injector seals on an MB quattro please? Looked on Mr Payne's website for a documented procedure, to no avail. Thanks in advance |
02-03-17, 01:31 PM | #2 |
Best to take the injectors out the head. There's a CIS tool although it's not that great to use. search for CIS injector puller
Watch you don't break the plastic inserts and ensure the shrouds don't fall in
02-03-17, 01:36 PM | #3 |
making wooden things
I use a open ended spanner about 12/13mm maybe (behind the fuel line connection, is it 14mm?) then stick something else in as a fulcrum the lever them and out, sounds rough but it's not really as long as you apply the force in the same alignment as they went in!
02-03-17, 02:18 PM | #4 | |
13mm spanner then a screw driver as a lever behind the spanner, got them out easily that way on the 5T, but if you rush it you can snap the fuel line connector for the injector |
02-03-17, 03:19 PM | #5 |
With Missfire (same school of midbutchery?)
Leave the injectors connected. Open ended spanner, big enough to go around the shaft of the injector, small enough to get a grip behind the nut on the line. Piece of wood to act as a fulcrum. If the seals are old (presuming same setup as WR), then they won't be so forgiving. Getting a good position so that you push out straight, instead of too much sideways is a big plus. Other useful items to have Ibuprofen Bandages Kitty litter for leaked fluids, like blood Elastoplast Super glue (for really big holes in personnel)
I wish they would keep the damned Chinese away now that I can go home, so that I can enjoy Fish amok and a draught Angkor Last edited by Hanuman; 02-03-17 at 03:22 PM. |
02-03-17, 04:11 PM | #6 |
02-03-17, 05:13 PM | #7 |
02-03-17, 06:09 PM | #8 |
02-03-17, 06:13 PM | #9 |
when you nods yer 'ead, i'll 'it it...
The problem, Tony, is not the hitting it with the hammer part. It's the failure to hit it, while accurately hitting something else.
02-03-17, 07:04 PM | #10 |
