Members: 13,759 | Total Threads: 40,056 | Total Posts: 470,826 Currently Active Users: 604 (18 members and 586 guests) Welcome to our newest member, ehopuvougutig |
27-03-18, 05:10 AM | #11 |
Is boost something you can check with ODB2? I have connector and adapter for ODB2...
27-03-18, 09:55 AM | #12 |
Yes, but depends on software. I've no experience with something else than definite diagnostic tool for VAG cars - VCDS - VCDS can draw nice graphs of various parameters, useful for such check.
27-03-18, 11:07 AM | #13 |
Low pressure fuel pump worn out?
27-03-18, 11:52 AM | #14 |
If you can get hold of anybody with VCDS it would help - at least you could see where the problem is. My B4 went sluggish - checked the pump timing and found out it was out, so slackened the 3 bolts off and tweeked it a couple of degrees and hey presto - back to normal...eventually a worn pump will need replacing, but it gets you out of immediate trouble.
Its a while since I had my B4, but having a full version of VCDS certainly helped keeping it going! Have a look at the Ross-Tech link below - it will give you an idea of what to look for. http://www.ross-tech.com/vag-com/cars/tdi.html Last edited by M4rkp; 27-03-18 at 11:58 AM. |
27-03-18, 03:13 PM | #15 |
...or simply buy in ebay some cheap chinese ross tech cable clone for 15-20 quid. Or, if you want to support them, and are not scared about limitations the fact that licence of VCDS-Lite is tied to one PC, buy VCDS Lite licence AND ordinary OBD2 cable which is based on FTDI chip.
27-03-18, 05:26 PM | #16 |
Just removed EGR and it looks pretty clean... not clogged up... there is deposit but as expected... will clean anyway tomorrow. Next step is turbo boost...
27-03-18, 08:54 PM | #17 |
make sure all the small vac hoses are good, I had a split one on a tdi and it made it very sluggish
