Members: 13,715 | Total Threads: 40,056 | Total Posts: 470,826 Currently Active Users: 689 (18 members and 671 guests) Welcome to our newest member, ucdukado |
27-06-16, 06:24 PM | #1 | |
NG code engine replace rings wout rebore?
All, The piston bores in my NG engine (120K miles) look nice. Do I have to have rebored or could I used new standard size piston rings in the engine? I am not sure about the UK, but reboring is quite expensive here.
27-06-16, 07:00 PM | #2 |
If there's no obvious wear and the bores haven't gone oval then there's no need to rebore it, a new set of rings gapped properly will be fine.
No step at the top of the bore I assume? |
27-06-16, 07:17 PM | #3 |
Thobbing Member
You need to measure them. Depending on the life the car has had, they are probably slightly oval. If you can't feel a step at the top the the bores with your finger nail, and you're not planning to go nuts with the engine (I'm guessing not on an NG ) they are likely fine to go again.
The main cost associated with a reborn is the new Pistons you need to go with it! |
28-06-16, 04:34 PM | #4 |
Dont forget if the piston rings are worn the grooves they sit in may also have worn too, which is why unless its a low miles engine itd be a false economy to re-ring it.
