Classic Audi Technical Mech/Tech Interior » Odometer still not working!
Old 21-12-16, 07:56 PM   #21
Gmac
Gmac's Avatar
Pictures of the circuit board, both sides are at the bottom of page one by the way Mark, have a look see what you think. I'd like to try and get this fixed.
I've just had a look at mine and it's a VDO cluster!
Gmac is offline   Reply With Quote
Old 21-12-16, 08:13 PM   #22
ChrisG
ChrisG's Avatar
It's probably been contaminated - by crumbs from that sandwich
Sorry , that's not helpful is it I've got to admire your tenacity though so good luck fixing it.
Old 21-12-16, 08:36 PM   #23
Hanuman
Hanuman's Avatar
Originally Posted by Gmac View Post
Have to say, can't see anything obvious.. Nothing burnt out... And without getting too much down in the weeds, how am I going to supply power to the motor to see if the cogs are spinning as they should?
Second one first.
Large black gear in the middle as reference.
At 9 o'clock, there is a mark across a track. Is it dirt, or a scratch? If the latter, is there a break in the track? Easy enough to check, with a DVM, measure (zero ohms) between the two component pins at either end of the track.
Slightly up from that mark is a large solder connection, which may well be to the motor. It's hard to tell in the photo, but it's got a couple of qualities that might suggest a dry(cold) joint. If you have a soldering iron, I would reflow all this connections. It costs little more than some time and a bit of solder.
First one second
The motor is likely controlled by that IC in the top right corner of the component side pic. It would be a little more complicated rigging this circuit to run without some other bits of kit.
It occurs to me that disabling the odometer would be a great way of hiding the mileage on the car.
enjoying a curry and a tiger beer
Old 21-12-16, 10:06 PM   #24
Gmac
Gmac's Avatar
Thanks for that Mark
I'll take a closer look at that scratch and get an DVM on it! And then I think you are talking about the lump of solder just next to the scratch? (The lower left of the two similar ones close by the scratch?). I can take a closer pic. Macro the **** out of it! Lol
I have got a soldering iron but would be very under confident in using it. Would I just need to put a dab on the scratch, and then a further dab on the nearest 'lump', or does the lump just have to be livened up with a hot iron?
There is a breaker b4 1.9tdi in Aberdeen which I could go and take a look at I suppose.
And yeh, going through this process I've learnt how to clock an old car! Lol. Kind of why I want to get this one fixed, so as to show honesty down the line.
Old 21-12-16, 10:10 PM   #25
audi80fan
True enough, although with the MOT history check these days you'd have some explaining to do anyway.
Things have certainly come a long way though compared with the looks of these clocks.
audi80fan is offline   Reply With Quote
Old 21-12-16, 10:27 PM   #26
Hanuman
Hanuman's Avatar
For reflowing solder
Option one. A quick once over that I've been guilty of, also. Just reheat it, and let it cool as normal. However, if there's any contamination on the competent leg, this may be a temporary fix.
Option two. I usually wick off the old solder, apply flux, and fresh solder.
My usual boot tool kit has a gas soldering iron courtesy of Maplin
http://www.maplin.co.uk/p/pro-iroda-...iron-kit-n12ar
along with solder wick (copper braid which is used to remove old solder)
http://www.maplin.co.uk/search?text=...+braid&x=0&y=0
and flux.
http://www.maplin.co.uk/p/flux-dispensing-pen-n63aa
Old 21-12-16, 11:43 PM   #27
If yours is VDO, you can probably use bits from the Ebay cluster.
You can use a multimeter to check the traces on all the tracks to the IC. You should have continuity to all pins
1993 S2 estate
mikes2 is online now   Reply With Quote
Old 22-12-16, 06:48 PM   #28
Gmac
Gmac's Avatar
Well I tested all the tracks on the circuit board and all measured 0.00ohms. Everything does look ok...so had another look at cogs etc and I found this...the missing cog! On the end of my finger.. Same colour as the old small cog. It was jammed in amongst the other cogs....I just wonder if this was stopping something!!!!
Will put it back together and go for another drive! Fingers crossed, again!! Lol
Old 22-12-16, 07:02 PM   #29
audi80fan
Ha, well done. That definitely deserves a beer.
Old 22-12-16, 07:24 PM   #30
Duffy3074
Hopefully finally done.
Good job for persevering
Duffy3074 is online now   Reply With Quote
