Members: 13,907 | Total Threads: 40,056 | Total Posts: 470,827 Currently Active Users: 605 (15 members and 590 guests) Welcome to our newest member, uqamayol |
09-11-18, 10:40 AM | #1 | |
1994 Audi Coupe 2.0e ABS issues
Hi guys.
Wonder if you can help. I have been fixing up an 80 Coupe for the past couple of years. Its now ready for MOT but i cannot get the ABS light out. Now all brakes have been removed, renewed, subframe off etc so everything is new. I cannot remember if the light was on when i got it, as it didnt run. Ive had it on VCDS and the ABS controller cannot be communicated with. Ive checked the ABS ECU and and got a spare to try that but makes no difference. Only thing i can find is that the ABS ECU only gets a 6v feed - without a diagram im not sure if thats enough or if the only feed required? Any thoughts? |
09-11-18, 11:07 AM | #2 |
Have you checked the fuse on the ABS relay? it's located under the dash behind the ign switch:
I've had a relay die, which is why I have a photo of one
1992 80 quattro 20vt |
09-11-18, 11:16 AM | #3 |
Hi, i saw this on another forum so went looking for that relay, but cannot find it, do all Coupes have them? Cheers
09-11-18, 11:28 AM | #4 |
09-11-18, 11:55 AM | #5 |
Aero Advocate
If its not where Ben said that ABS relay also can sometimes live under the back seat...
09-11-18, 01:22 PM | #6 | ||
Looking through some Audi B4 pdf's, it states (for LHD):
09-11-18, 01:31 PM | #7 |
For a 94 car, there is no relay. It's all contained in the ecu under the rear seat.
If you start the car up, the ABS light should go off within 5 seconds. If it doesn't it's likely a pump / modulator fault since you've already swapped the ecu. There are 2 relays in the modulator which can be swapped out
09-11-18, 02:22 PM | #8 |
Thanks guys. Nah light stays on. It’s not turned a wheel for over ten years so I do wonder if once it’s had a drive it’ll sort itself out. I’ll keep you posted.
Cheers |
09-11-18, 03:03 PM | #9 |
Aero Advocate
Good luck
10-11-18, 01:03 PM | #10 | |
