Classic Audi Technical Mech/Tech Transmission » 1983/84 Audi 80 Quattro 5th gear ratio??
Old 19-09-17, 06:49 PM   #11
Audi-Ant
Originally Posted by slammedAudi View Post
The 1.8 gearbox used in the 80q is for a 4 pot engine, and the bellhousings are different 4 versus 5 cyl, so that couldn't be the case.....
You sure they dont have both sets of holes like the tor-sen ones??? Torsens are interchangeable i gather
Audi-Ant is offline   Reply With Quote
Old 19-09-17, 09:08 PM   #12
slammedAudi
Torsen is a differential, not a gearbox..........
The gearbox in the 1.8 litre Audi 80 was 4.56 : 1 as far as I know.
slammedAudi is offline   Reply With Quote
Old 19-09-17, 10:22 PM   #13
Val
Val's Avatar
Originally Posted by Audi-Ant View Post
Hello, anyone know the answer to this???
I have just bought a 1983 KK Quattro, it does 17.5mph/1000rpm in 5th. I also have a KV engined type 85 90Q, and this does 20.5mph/1000rpm 5th...
Is that how the KK is meant to be? Or had it found the box from a 1.8 Quattro at some point??
Post your gearbox code.
B2 4cyl 1.8q gearbox is not bolt-on to 5cyl engine.
Val is offline   Reply With Quote
Old 20-09-17, 07:41 AM   #14
Audi-Ant
Sounds like your trying to make me look daft chum...
Audi gearbox with Tor-Sen diff then, you knew what i meant....
Old 20-09-17, 07:45 AM   #15
Audi-Ant
If they really wont fit together, then either the gear sets have been replaced, or the rev counter over-reads. Since my mate has just dynoed his 90CD, and the rev counter over-reads... Then its possible. Think his CD said 8000@ a true 6500
Old 20-09-17, 11:51 AM   #16
slammedAudi
Always glad to lend a helping hand
As someone else has also said... a 4 cyl engine needs a box designed for that engine, ditto for a 5 cyl. If our B2 engine is a KK, a gearbox for a 1.8 won't physically fit it.....
It's a difficult job to fit the internals from a 4 cyl box into a 5 cyl box..... Possible but not easy. Much easier and cheaper to just get a replacement box in the event of a failure
At this point you should have a look at the number stamped into the top of your gearbox bell housing close to the back of the engine.
Also....
Have a look at your speedo and see what part number is printed on the front of it (if visible), and also the "W=....." number.
That information will help. Is your speedo giving a reasonably accurate figure?
Old 20-09-17, 05:59 PM   #17
Audi-Ant
Also....
Spedo is only about 2mph over (surprisingly), by a phone app and sat nav for comparison. So no problem there...
My MK2 Golf must over-read by 10%, its well off. This KK is nearly right
Just found 6B15 on the top of the box...
Spedo W=1740
VDO
811 190
Thats how it reads coming down the clocks, the 811 190 is tiny!
Hope this sheds some light, ad many thanks
