Classic Audi Technical Mech/Tech Bodywork, glass & exterior fitments » C3 Bonnet Adjustment question
Old 11-07-18, 07:33 PM   #1
Ringmaster
Ringmaster's Avatar
Default C3 Bonnet Adjustment question
Folks,
Twenty seven years ago my C3 had a new offside front wing fitted and the front edge of the bonnet is slightly proud of the wing (barely noticeable).
Consequently, the front offside corner of the bonnet had a tendency to pop up now and again. After some fettling of what looks like a hexagonal shaped adjuster at the base of the offside bonnet spring, this stopped.
However, the more I turn this to bring the bonnet down, the greater the bonnet's desire to start popping open again.
Am I doing something wrong? Any tips appreciated.
Old 11-07-18, 09:57 PM   #2
theschmallfella
theschmallfella's Avatar
I wonder has the receiver in the front panel weakened? Also it might be worth considering that the bonnet hinge on that side might need a little adjustment? Open the bolts that attach the hinge to the bulkhead just slightly (enough to get movement but not enough that it's moving freely) and then close the bonnet and see if that helps. If it does then just tighten them up again. I had a similar issue in a 100 I had after a front end repair.
Old 12-07-18, 04:01 PM   #3
Ringmaster
Ringmaster's Avatar
Thumbs up
Thanks.... I'll have a look....
Old 12-07-18, 09:46 PM   #4
theschmallfella
Let me know how you get on
