Members: 13,590 | Total Threads: 40,056 | Total Posts: 470,824 Currently Active Users: 838 (17 members and 821 guests) Welcome to our newest member, dujpoclrepa |
21-12-16, 11:18 PM | #1 | |
B4 discs on a B3?
Being the prize twit that I am, I've just spotted the fact that the mintex discs I bought are B4 size (larger diameter). Has anyone used these bigger discs on a B3? Are there any mods that are needed to do so that I can use these bigger discs, or do I shell out for the proper size and hope that the wife doesn't notice......
21-12-16, 11:47 PM | #2 |
There are different sizes used on both B3 and also on B4 - usually dependent on engine size but also chassis number dependent.
There's also the problem that B4 cars used different hubs so the offsets changed. The B4 discs you have - are they 280mm ?
22-12-16, 03:14 PM | #3 |
280mm indeed. The 'hole in the middle' is fine and they are vented.
22-12-16, 03:24 PM | #4 |
Oh and its a 2.0E 8v, if that helps.
22-12-16, 03:53 PM | #5 |
They'll not work unless you can source a set of carriers from a B4.
There's a 10mm difference in height on the B4 discs
23-12-16, 07:57 PM | #6 |
Thanks Mike. So an interesting dilemna; if i obtain new carriers, I will be stuck with using B4 discs but B3 bits are getting a bit harder to come by. I'll ponder until after Christmas.
Have a cool Yule. |
