Members: 13,607 | Total Threads: 40,056 | Total Posts: 470,826 Currently Active Users: 812 (22 members and 790 guests) Welcome to our newest member, dajimubase |
15-09-13, 11:45 AM | #21 |
Well, B3/B4 G60 discs shouldn't be very expensive either, I'm only wondering if they would relieve you of the need of adapters or not, as I think that two piece struts have different offset than one piece. But you can also do it properly and make front suspension upgrade - since you already have Bilstein B6 shocks for "civilian" B2/B3/B4 struts, you have no need for S2 struts, as for the rest, the donor is B4 2.8 - since you're talking about 4000, I presume you're in states, so such donor car should be easier to find for you, as it seems to me there weren't smaller engines for US market [am I wrong? ] - only it will involve fitting outer CV joints on front driveshafts [if you're still using B2 gearbox] and it will involve changing front brake lines, because they end in different place because of shape of anti rollbar, which don't permit using the old brake line setup. Afterwards you can use B3/B4 G60 discs and no need for adapters for calipers, or you can go for 5x112, which involves expensive and hard to find S2 hubs or, more often, turning some C4 hubs to fit, as they require small reshaping for this application. Afterwards, ordinary B4 G60 discs can be redrilled, or S2 discs fitted, only they are quite expensive and hard to find. Since I don't like both of these options, when I'll finally go for 5x112, I want to try what happens if B5 front hubs are fitted together with B5 discs - will they line up with G60's or offset will be different - and I wouldn't mind if someone would check that out before me Rear 5x112 upgrade has been found by some to be very simple - B5 quattro rear hubs [on such a old cars that involves rear outer CV joint or whole driveshaft swap] and brake discs, and that's about it.
15-09-13, 12:25 PM | #22 | ||
Regarding a 5x112 conversion I've concluded I won't do anything about it until I'm forced to. |
15-09-13, 01:01 PM | #23 |
Fitted one to mine way back in 1997 and one of the best mods I've done, reduced the understeer and removed the rolling rear of the csar and made the whole car more stable.
Have a article on mine if interested, just PM your e-mail address. Having driven a few 'normal' ones it confirms it is a worthwhile upgrade.
15-09-13, 01:12 PM | #24 |
Understeer or oversteer?
Btw, how it happens that your middle silencer does not interfere with driveshaft, despite being wrong one? |
15-09-13, 02:18 PM | #25 | |
That's like I mentioned above, early wishbone mount arb, some of the wishbones you can buy actually come with the bushes installed.
15-09-13, 02:21 PM | #26 |
[quote=msh;325258]Understeer or oversteer?
QUOTE] I think the front bar on the rear makes the car fairly neutral, you can provoke understeer or oversteer as required. As stock they tend to understeer unless you are particularly forceful. Car corners much flatter as well.
15-09-13, 03:14 PM | #27 |
You're probably talking about tarmac, while I'm thinking about gravel, because the rear end of my A90q has a strong tendency to slip out of the corner, which should not happen, and which is probably caused by incorrect geometry adjustment, as the front and rear appeared to be in different angles. Will try to adjust after the rear end of the car will be in one piece again.
How nicely front ball joints fits in rear struts? Just interest, I won't fit anything like that, despite having most of the needed parts at hand, because it would cause my car fail technical inspection without any doubt. |
15-09-13, 09:22 PM | #28 |
[quote=Andy10v;325267]Thats my conclusion too, I used the front bar from an early quad lamp GT (20mm) modified to suit.
15-09-13, 09:41 PM | #29 | |
Getting the car properly aligned makes a huge difference to handling! (Though bushes need to be good or you get changes in alignment as they deflect) Never tried front ball joints in the rear. If you use all factory parts (especially used ones) the nobody will notice unless they know the cars very well. Also as there were early cars with rear arb, then ones without, then arbs again, also different diameters.
15-09-13, 10:42 PM | #30 |
Thobbing Member
I recognise that rear subframe. Sadly it is less shiny these days, 5 years of abuse have taken their toll!
That was a 22mm rear bar, matched by a 26mm S2 bar up front and it was an excellent, cheap setup. As said uprating the rear roll stiffness of these chassis cars is pretty much the best handling mod you can do to an otherwise stick car and I would say essential if you are doing any track driving. When dialled in right it makes the balance far more neutral and understeer can be completely eliminated with appropriate driving. Lift-off oversteer is also a welcome addition - makes the car into a giant hot hatch. Add a Torsen rear diff too and you are into a whole different league of fun |
