Classic Audi Technical Mech/Tech Engine » Fuel system pressures - B3 KV
Old 27-10-20, 04:31 PM   #1
Duffy3074
Default Fuel system pressures - B3 KV
Guys
Been checking the operation of the WUR on E-Lad today with a pressure guage. Anybody have a definitive answer on the correct pressures and temperatures for it?
Part number for the WUR is 035 133 403E
Cheers
Old 27-10-20, 07:35 PM   #2
There's numbers for this in my 2.6 thread. I had the regulator rebuilt so before & after...
System pressure set to 5,0 bar.
Cold at 10 degrees 0,9 bar.
Cold at 10 degrees with 600 mbar vacuum at the side port 1,6 bar.
To heat up the bi metal at 13,5 volt has 1,08 ampere.
Warm the control pressure was 2,9 bar.
Warm the control pressure with 600 mbar vacuum was 4,1 bar (to high)
After rebuild
Cold at 10 degrees 0,4 bar.
Cold at 10 degrees with 600 mbar vacuum at the side port 1,0 bar.
To heat up the bi metal at 13,4 volt has 1,01 ampere.
Warm the control pressure was 3,0 bar.
Warm the control pressure with 600 mbar vacuum was 3,5 bar
1988 90 quattro 2.6
Old 27-10-20, 07:52 PM   #3
Duffy3074
Thanks Mike, I did flick through your thread and saw the pictures of your new WUR but didn't see the figures
Much appreciated!
Old 27-10-20, 07:57 PM   #4
July last year was when it got done. rebuild was 275 Euros.
KMI - never answer the phone
ATP - they were moving premises and couldn't help for 3 months
Ferrari400parts got the business.
Think they sell the kits if you're feeling adventurous.
1988 90 quattro 2.6
Old 27-10-20, 08:19 PM   #5
Duffy3074
Emailed KMI and got a reply within the hour, 200 plus vat plus postage.
Did think about a kit, the tricks in calibrating it afterwards
I’ve given it a good ultrasonic clean and will do a full cold to hot cycle once I’ve got a vacuum gauge and T piece.
It’s a lorra dosh!
Old 28-10-20, 05:07 PM   #6
Duffy3074
http://forums.pelicanparts.com/porsc...ed-my-wur.html
I’m tempted to go down this road and get a rebuild kit too.
All in between a third and half the price of getting it reconditioned
Old 29-10-20, 01:14 PM   #7
Duffy3074
Did a full cold to hot this morning
Ambient temp was 10 degrees
Cold start pressure was 1.4 bar 20 psi
Hot with vacuum was 4 bar 58-60 PSI
Hot without vacuum was 2.8 bar/40 PSI
So compared to Mike's rebuilt WUR it's all too high (which ties in with the emissions)
I didn't have a vacuum gauge but disconnected the vacuum line (which I blocked off obviously) for one of the readings and suddenly the car started to idle much more smoothly.
Steve at KMI had said that I should check that the WUR held vacuum and this would suggest to me that it doesn't albeit there's a possibility that the reduction in fuel pressure accounted for the better running
Interesting! Choice now is whether to DIY or not?
Old 30-10-20, 01:47 PM   #8
Duffy3074
https://www.ebay.co.uk/itm/184409839635
Ordered one of these, I’ve got what I need to mod it already, the kit comes with instructions that I’ll share here.
Diy’ing reduces the cost from 260 to 74.74 and means it’s adjustable
Old 30-10-20, 07:48 PM   #9
Mellis46
Aero Advocate
Mellis46's Avatar
Got to be DIY and a thread?!
Old 30-10-20, 08:12 PM   #10
Duffy3074
Being Scottish I’m reluctant to hand over my hard earned to somebody for something I can do myself
Bits are in the post
