Members: 13,578 | Total Threads: 40,056 | Total Posts: 470,824 Currently Active Users: 1098 (18 members and 1080 guests) Welcome to our newest member, odaulawukuz |
07-11-17, 03:38 PM | #1 | |
Engine fault codes
I've got a '87 coupe gt with a tsr brands hatch engine with pack c head. It has started cutting out when it hits 4.5/5k rpm. This is after a tensioner change, it did find a knackered capped vacuum pipe near the throttle body. If it has sensed the timing is out and put the limiter on, how do you clear it, before I have to take it to a garage ?
Jase |
07-11-17, 04:44 PM | #2 |
Unless Im very much mistaken, which occurs fairly frequently, there ain't no codes.
Rotor arm? Basic timing?
07-11-17, 05:14 PM | #3 |
What's a brands hatch engine and what's it based on ?
07-11-17, 07:30 PM | #4 |
[quote=Hanuman;436107]Unless Im very much mistaken, which occurs fairly frequently, there ain't no codes.
I agree there are no codes on the B2, no idea what a brands hatch engine is but I know what a TSR stage 3 head is - bigger valves fully gas flowed I have the original TSR brochure somewhere, is it a 4 or 5 cylinder ? as in VW golf 1.8 or Audi 1.9/2.1 ? and is it injected or carb, some basic info needed to get you help with this. Will be either fuel or ignition or could be both, is the belt a tooth out ? Ony limiter I know on these is the spring loaded rotor arm, no electronics just mechanical old school stuff. Last edited by quattrodave; 07-11-17 at 07:33 PM. |
07-11-17, 08:32 PM | #5 |
New rotor would be my first port of call, the rotor arm has a rev limiter built into it and the spring may have went week with age, a quick test would bet to super glue the rotor arm so the rev limiter is disabled.
09-11-17, 08:48 AM | #6 |
It was a 1.8, now taken out to 2ltr
http://www.tsr-performance.com/websh...valve-package/ It's had a new rotor arm, will check the cap though it should be fine. |
09-11-17, 08:58 AM | #7 |
If you don't want to super glue your new rotor arm fit one without the rev limiter, you can buy one, just a thought, you rev limiter may be getting triggered because you have reached your rev limit but you rev counter could be reading low.
20-11-17, 09:25 PM | #8 | |
Is the spring inside the rotor arm or is it part of the distributor? |
20-11-17, 09:30 PM | #9 | |
[quote=quattrodave;436125]
20-11-17, 10:17 PM | #10 |
What timing marks were checked?
The mark on the crank V belt pulley is not reliable. Flywheel, cam gear and dizzy.
