Classic Audi Technical Mech/Tech Electrical problems » This is a strange one !!
Old 25-05-18, 06:15 PM   #1
urquattr085
urquattr085's Avatar
Default This is a strange one !!
Jumped in the quattro this morning to go to work,
This is how things went.............
Turned on ignition, all fine. Alternator, abs and oil pressure lights come on.
Started the engine, all fine. Alternator, abs and oil pressure lights go out, car ticking over ok.
Pulled out of the garage and set off to work. Anything over 2000rpm and the oil pressure light came on. Dipped clutch, let engine go to idle, oil light goes out, increase revs to 2000rpm or so, oil light comes back on.
After mile all back to normal, no oil light.
On the way home, no issues at all.
Any thoughts? I was suspecting faulty sender?
Thanks all
1985 WR quattro
1983 80 Quattro - Sold many moons ago
Old 25-05-18, 06:48 PM   #2
Either that or a bad connection caused by dampness / condensation that cleared once it got a bit warmer
1993 S2 estate
mikes2 is online now   Reply With Quote
Old 25-05-18, 07:18 PM   #3
Duffy3074
What was the oil pressure gauge doing??
Old 25-05-18, 07:23 PM   #4
urquattr085
Cheers Mike.
Could be, it'll get a clean up and a new connector at the weekend and see how we go.
Oil level is bang on top of the full mark and it didn't sieze today so nothing too much wrong, hopefully
1985 WR quattro
Old 25-05-18, 07:23 PM   #5
urquattr085
Hi Duffy
No oil pressure gauge on the Ur
1985 WR quattro
Old 25-05-18, 08:06 PM   #6
Duffy3074
You what????
The digital dash performs that role I assume
Old 25-05-18, 08:30 PM   #7
urquattr085
You what????
Oil pressure warning light, digital oil temp gauge in centre console and vocal warning for oil level
1985 WR quattro
Old 25-05-18, 08:49 PM   #8
Colin Aitchison
Colin Aitchison's Avatar
I had a similar problem with my 1987 Audi coupe GT when it had the original 10v KV engine,
oil light cam on above 2200rpm, oil level was ok, I think I removed the oil pressure relay and it never happened again but I think the Ur quattro's have different wiring, I think Mike might have hit the nail on the head with condensation or bad connection.
Old 25-05-18, 09:02 PM   #9
urquattr085
Hi Colin, don't think they have a relay and no evidence from a quick check of the wiring diagram. Will clean up all connections and see where we go.
Cheers for the input
1985 WR quattro
Old 26-05-18, 02:13 PM   #10
M4rkp
M4rkp's Avatar
They do have a relay #234 - part no 857 919 082
Check the sender first - the 'can' type thing RHS of engine ( as you look at it) there are 2 connections but only one of them used.
Unscrew it and clean the small hole out with carb cleaner.
You say you are getting oil light coming on - are you not getting warning triangle light up and voice alert?
M4rkp is offline   Reply With Quote
