Members: 13,473 | Total Threads: 40,056 | Total Posts: 470,823 Currently Active Users: 477 (2 members and 475 guests) Welcome to our newest member, eeweacejemol |
19-10-21, 09:39 AM | #1 | |
PAS Vane Pump MB ur quattro, or rebuild kit?
Hi
I am looking for a new/replacement pump, or failing that a rebuild kit. Mine has a slight leak. Any advice on where to get one much appreciated! I think the part number i need is 034145165 (for the pump). Thanks
19-10-21, 01:36 PM | #2 |
you could be in luck. I'll check the garage
19-10-21, 01:44 PM | #3 |
I wish i had a garage like yours!!
Thanks Mike.
19-10-21, 05:30 PM | #4 |
Rebuild ... Gasket set is peanuts compared to new'ish pump and it takes 10 minutes longer compared to just swapping the pump...
Pump is from Cabrio 2.3E, gasket set is for other type pump than LUK. Audi uses two types of pumps ... 50% chance of getting the right one ... Failed that ;-) |
19-10-21, 07:05 PM | #5 |
The MB uses a tandem pump, not a vane type pump.
I've sent you a message Stuart
19-10-21, 08:12 PM | #6 |
As I wrote. Audi use two different pumps. In my case with the Cabrio 2.3E - some have the tandem pump and some have the vane pump. Notice the picture, pump is vane type and gasket set is tandem type. ;-)
20-10-21, 08:07 AM | #7 |
Part number for the rebuild kit is iirc: 026 198 049B.
Anywhere from 6 to 16 quid. |
20-10-21, 03:09 PM | #8 | |
035 198 049 A https://www.ebay.com/itm/362533347161 026 198 049 B <== This is the one for my LUK pump and also most Mercedes models. https://www.ebay.com/p/671155714 |
