Classic Audi Technical Mech/Tech Electrical problems » Heated seats - after market elements?
Old 17-10-21, 09:41 AM   #21
BackintheFold
BackintheFold's Avatar
Is there a choice?
I suppose I can Cut all of the pad except for the bits that go around the hog rings, but that might burn out the small amount of wiring going through there.
I’ll understand a bit better when I take the leather cover off, but I thought the wire that holds the leather to the wire in the seat is in a loop of material that is attached to the leather.
No?
2006 A3 (daily drive)
BackintheFold is online now   Reply With Quote
Old 17-10-21, 10:09 AM   #22
Duffy3074
I can’t speak to the specific internals of the Audi seat but we’re not talking about a gazillion volts or internals of the sun temperatures here.
As long as you leave a circuit around the whole pad it will heat up quite happily and evenly. the bar usually just affects the centre section of the pad, there’s usually plenty of room to run the necessary pad around it without any problem on the half dozen seats I’ve done.
To reassure you I spent time with my heat measuring gun and, outwith a very small variance in temperature (undetectable to a jean clad buttock) I ended up with a cozy and evenly heated seat.
It’s one of these jobs that’s easy to overthink
Old 17-10-21, 10:20 AM   #23
BackintheFold
The barvgoes the whole way across the seat pad. Not the bolsters but the heated pad isn’t wide enough for those anyway.
Old 17-10-21, 10:25 AM   #24
Duffy3074
What do the instructions that come with your kit say to do?
Old 17-10-21, 12:31 PM   #25
BackintheFold
Good point.
Not here yet.
Will confirm when I can.
