Members: 13,695 | Total Threads: 40,056 | Total Posts: 470,826 Currently Active Users: 785 (19 members and 766 guests) Welcome to our newest member, utuimah |
23-06-21, 02:56 PM | #11 | |
Incidentally, the screw I removed has a vertical crack in the side of the cap head. Not a failure mode I've seen before. Have you ever seen a cracked bearing support housing as a result of loose/missing screws? If the screw can crack I guess the bearing housing can too. |
23-06-21, 03:03 PM | #12 |
Image of cracked screw (90Q rear output shaft bearing housing)
23-06-21, 04:06 PM | #13 |
I take it there's no room for a grip socket in the space available ?
These have saved my bacon a few times on rounded cap bolts
24-06-21, 07:59 AM | #14 |
Sorry to hear it wasn’t successful. It would seem someone has been there before you and failed. The split bolt, I suspect, is as a result of a previous removal, I’m guessing someone hammered something to big in there, it had the desired effect in that I would imagine they removed it but then failed on the last bolt which is why the splined socket trick won’t work. I would do as you said replace the two and keep your fingers crossed.
I have never known a housing to split. |
24-06-21, 08:08 AM | #15 |
Have you got a mig welder?
Weld a small bolt in there. Don't forget to remove you ecu's first. |
24-06-21, 02:35 PM | #16 |
Unfortunately, it's about 10mm down inside a counter-bore - so pretty inaccessible. Thanks for the suggestion though. I've never used a grip socket - sounds like it worth having in the tool kit.
24-06-21, 02:38 PM | #17 |
24-06-21, 02:42 PM | #18 | |
24-06-21, 03:58 PM | #19 | |
30-06-21, 08:31 AM | #20 |
Thanks for the link John. Much appreciated.
Tags |
90q, gearbox, rear output shaft, seal |
