Members: 13,592 | Total Threads: 40,056 | Total Posts: 470,825 Currently Active Users: 836 (19 members and 817 guests) Welcome to our newest member, ikegumaf |
28-03-16, 01:40 PM | #1 | |
Bit tappety even when warm
Hello - my 1986 90 with the 115bhp 5cyl engine is a bit tappety even when warm. On a cold start it isn't especially noisy, but when I'm cruising along and the engine is at normal temperature I do hear a tappety noisy bouncing off walls when I'm driving along with the windows are down.
Is there an additive I can put in there that someone has had good experiences with to clean things out? Or should I get get my indie specialist to have a look if things need replacing? Car has 97,000kms from new, and has had a recent oil change, and generally always well looked after, but not sure if oil changes have happened on a yearly basis in the last 5 years or so, as there's a bit of a blank spot in its near complete service history for that period. |
28-03-16, 02:17 PM | #2 |
Seems like a relatively low mileage to be giving tappet problems.
It might be worth checking to see you have an exhaust manifold leak. This can give you a persistent ticking sound similar to a problem tappet, the cause of which is usually a blown gasket and/or stud issues at one end or the other of the manifold. |
28-03-16, 05:23 PM | #3 |
I change my oil 2-3 times a year on my 85' cq. When I first got it a couple of years ago, it was also a bit tappety even when warm. One weekend I changed the tappets amoung many other things and they've been fine ever since. Their readily available from tps.
6 months ago I thought oh no the tappets again, like what lefthooker said, it turned out to be the gasket had blown on the exhaust manifold.. Good luck. Andy
1985 Coupe Quattro 1986 Coupe 1.8 weber carb 1987 Coupe 2.2 GT |
28-03-16, 06:38 PM | #4 |
Thanks for the messages and tips. I'm no mechanic, how would I check for the gasket on the exhaust manifold?
28-03-16, 06:43 PM | #5 |
Get your hand in! Check for rushing air around the manifold. Might be better on ramps
