Members: 14,980 | Total Threads: 40,057 | Total Posts: 470,834 Currently Active Users: 899 (27 members and 872 guests) Welcome to our newest member, otauexuafzo |
01-09-17, 12:51 PM | #1 | |
Magnetic vacuum valve NF
Hello guys,
I have some trouble with my magnetic vacuum valve (I think). For good measure it is for part nr: 3911070906. It's from an 1988 Audi 100 with new NF engine. It connects hoses from the carbon filter and the throttle valves. When the engine is running it makes a regular ticking noise. Hereby I measured the signal and got the idea that there is also comming a pulse signal from the source. My volt meter is too slow though to get an accurate reading of the true signal. I might run it through a scope soon though. My problem is that I have some idle stabalisation problems while engaging the clutch and some cold start problems. (I might make a separate topic on that) I can't really seem to find what this valve actually does and what signal it should get. should it tick so loudly and rapidly? At first I though that the ticking sound was a valve, so that's the kind of sound you can expect. Does this harm, and does it have influence on idle running for example bypass air running into the air intake? If someone have a diagram of the signal this valve should get would also be very helpfull. Thanks in advance guys! |
