Members: 13,648 | Total Threads: 40,056 | Total Posts: 470,826 Currently Active Users: 780 (16 members and 764 guests) Welcome to our newest member, MuskWes |
02-05-18, 12:08 PM | #1 | |
Audi 80 b2 1.8 front carriers
Hello,
Iam looking for Audi 80 b2 1.8 front carriers (code 855 615 125) in order to upgrade my front brakes with the 239X20 vented discs. Anyone have them? |
02-05-18, 03:43 PM | #2 |
Why not go straight to G54's with 256x20 discs? Need to keep some 13" wheels?
02-05-18, 05:30 PM | #3 | |
If I remember correctly the standard solid disk caliper will not fit over a vented disk. I found it very hard to source original Audi stuff when I looked into this a few years back. Another route is to source Golf GTI MK1 (or an early golf MK2 parts?). There are some conversations on Golf MK1/2forums on uprating to the later 239x20 discs. If I remember correctly the magic number is 75mm. This is the distance between the caliper mounting bolts which will go over a later vented caliper. The non vented carrier bolt distance is 55mm IIRC. If you already have the larger caliper all you should need is a carrier. However its not easy to find second hand Golf or Audi carriers. Though the Golf Cabriolet route may be easier as they made them into the 90's Hope that all made sense. I am not sure its 100% accurate so please double check and research. |
02-05-18, 09:50 PM | #4 | |
In any case I personally would look at getting A90 running gear and brakes - although in greece they might be hard to get... |
03-05-18, 07:22 AM | #5 | |
If not, your tip is my another solution.... |
03-05-18, 07:27 AM | #6 | |
The 239x20 set up equipped only the Audi 80 b2 1.8 and Audi coupe b2 1.8 and these cars were rare in Greece due to high taxation. So I have to follow your tip about the MK1 Golf Gti and MK2. Thank you very much! |
03-05-18, 07:30 AM | #7 | |
03-05-18, 08:28 AM | #8 |
