Members: 13,610 | Total Threads: 40,056 | Total Posts: 470,826 Currently Active Users: 816 (19 members and 797 guests) Welcome to our newest member, udapapacayu |
23-02-19, 03:28 PM | #11 |
Post them up here and we'll attempt to assist
24-02-19, 08:11 AM | #12 |
Here is the report that was initially generated, but when I cleared these the faults they have not come back so I am assuming they are historical issues.
The problem that I am trying to fix is difficult starting on cold days, so I'll see what is reported after I have had a chance to try that. Address 01: Engine Labels: Redir Fail! Part No: 039 906 022 Component: DIGIFANT 1.6 1243PMC 11 VCID: 4FFB71E78EC1321F577-0962 5 Faults Found: 00523 - Intake Air Temp Sensor (G42) 30-00 - Open or Short to Plus 00522 - Engine Coolant Temperature Sensor (G62) 34-10 - No Elaboration Available - Intermittent 00552 - Potentiometer for Air Flow Meter (G19) 31-00 - Open or Short to Ground 00525 - Oxygen (Lambda) Sensor (G39) 03-00 - No Signal 00524 - Knock Sensor 1 (G61) 03-00 - No Signal Readiness: N/A ------------------------------------------------------------------------------- Address 02: Auto Trans Labels: None Part No: 097 927 731 CH Component: AG4 Getriebe 097 1326 Coding: 00000 Shop #: WSC 00000 VCID: 6889BA7B0B6FC52736D-0964 No fault code found. ------------------------------------------------------------------------------- Address 03: ABS Brakes Labels: 4A0-907-379.lbl Part No: 4A0 907 379 A Component: Bremsen-Elektronik Shop #: BB 33837 VCID: 290FFF7FD0E53C2FE93-4B3C No fault code found. End----(Elapsed Time: 01:29, VBatt start/end: 12.4V/12.4V. VIgn 0.0V)------ |
24-02-19, 12:30 PM | #13 |
That's normal procedure.
Clear the codes and go for a drive. Re check the codes. There's usually a date stamp on the code which tells you when it was generated
12-05-20, 07:23 PM | #14 |
Digifant Control Module Maps
I have a 1993 Audi 80 2.0E with and ABK engine and a Digifant II ECU which is failing to accelerate or rev above about 3000RPM.
I have a Ross Tech VCDS OBD reader and the engine is not showing any error codes at all despite clearly having problems. Does anyone have a map for the control modules so that I can try to identify which sensor is which in the reports and see if any of them are the cause of my problems? Thanks in advance. RichardV |
