Members: 13,592 | Total Threads: 40,056 | Total Posts: 470,825 Currently Active Users: 833 (17 members and 816 guests) Welcome to our newest member, ikegumaf |
15-08-17, 02:29 PM | #11 | |
Just the man i wanted to make a reply, so maybe you could help me decide if i need the accumulator or not on the type 43 200 10v turbo i have, or should i not bother with it, i got hold of one last year. |
15-08-17, 03:10 PM | #12 |
IMHO if the engineers have decided that it needs to be there, and you have working one at hand, use it. If you would have just faulty one, that would be good reason for not to use it...
My previous and likely last KE-jetronic powered cars were B3 2.0 8v and B3 2.3 10v - on first one without accumulator I experienced some small strange things, but that was probably because of fuel pump. On A90q it was fine, also when for some time it was disconnected. If the A90q will run again, it will probably lose accumulator, but just because it won't contain KE-jetronic anymore... |
15-08-17, 03:22 PM | #13 | |
Those were the lines i was thinking along msh, thank you for taking the time to reply to my question I hope the A90q runs for you again. |
15-08-17, 04:07 PM | #14 | |
I bought a new one 2 months ago off ebay £75 delivered. There are many oem numbers and some that cross over. |
15-08-17, 04:15 PM | #15 | |
Wish i knew more about this stuff, only know what i read Do warm up regulators just go duff or can they be sorted ? Is it possible to do a test by unplugging it ? |
15-08-17, 05:54 PM | #16 |
The electrical connection on the WUR is for a heating element inside it, so disconnecting it could prove inconclusive - you really need to measure fuel system pressure and then control pressure to determine if the unit is faulty or not - if you remove the WUR from the block and turn it over you will see a blanking plate, underneath this plate is a grub screw which alters the amount of travel that the needle valve makes, therefore affecting control pressure of the metering head.
All of the Bosch WURs are basically the same - they are just set to different pressures for different vehicles -On my quattro I am running a WUR taken from a Golf - I have altered the grub screw to give me optimum control pressure at full working temperature. |
15-08-17, 06:08 PM | #17 | |
Thanks for the reply Mark I am confident the WUR will be the same age as the car (37 years), can this part dry up the same as a fuel distributor ? or perhaps just go faulty suddenly ? If this happens can they be sorted or is it a replacement that is needed ? |
15-08-17, 08:37 PM | #18 |
The main purpose of the pressure accumulator is to hold the fuel in the injector lines at pressure after you shut down to prevent the fuel boiling in the lines causing vapour lock and resultant hot-start problems.
If you never get starting problems with a hot engine, don't worry about it, but you might get a problem after a long / spirited drive on a hot day... |
16-08-17, 07:31 AM | #19 | |
Have a look at these people - I have used them before. http://www.kmipetrolinjection.co.uk/ Mark |
16-08-17, 12:04 PM | #20 | |
Great explanation there jimh, many thanks. |
