Members: 13,617 | Total Threads: 40,056 | Total Posts: 470,826 Currently Active Users: 809 (18 members and 791 guests) Welcome to our newest member, oqehavaweqc |
31-05-18, 04:42 PM | #1 | |
Renovation kit for brake master cylinder
My Audi 100 2.3 quattro -92 is leaking from its master cylinder, between the oil reservoir and the master cylinder itself. I have just driven with it as is before, since the brakes worked fine and I only had to top up occasionally. Now however the warning light for the brakes are always blinking, before I just topped up on brake fluid and it stopped. So I think its time to fix it. I could just go to a junkyard and pick up another one, but is there a repair/renovation kit on the market one could buy?
And do you think this could have anything with the problems I've described in the thread below? The brakes are controlled partly by vakuum. http://www.classic-audi.co.uk/forum/...ad.php?t=36240 Best regards Niklas |
31-05-18, 04:53 PM | #2 |
Hey Niklas,
I don't know enough to say whether your other problems are related to this, but I have been told that getting into a master cylinder is a brutal process, so it may be better to purchase a new one for all that repairing it would entail..... I know there are wiser heads on this forum... |
31-05-18, 05:55 PM | #3 |
Did mine, it was just a circlip to get access and a seal kit thereafter. Straightforward stuff as long as you are careful and keep it clean
31-05-18, 08:57 PM | #4 | |
31-05-18, 09:04 PM | #5 |
What I just did - I opened up ebay, wrote "volkswagen brake master cylinder reservoir seals" and ended up with this https://www.ebay.com/sch/i.html?_fro...seals&_sacat=0 . I wrote volkswagen, because both used Girling stuff, but VW is internationally more popular.
As for your engine running problems - it's hard to point at something - I usually just go over all the system checking if all is fine. I've created KE-jetronic diagnostic thread in this forum, btw. |
01-06-18, 06:53 PM | #6 | |
Also read the thread you did about diagnostics on the KE-jetronic system. I will give it another go when I get back home on trying to locate the fault. |
07-06-18, 09:28 AM | #7 |
Try onlinecarparts.co.uk
