Members: 13,680 | Total Threads: 40,056 | Total Posts: 470,826 Currently Active Users: 789 (17 members and 772 guests) Welcome to our newest member, aqanoweta |
16-09-17, 05:13 PM | #1 | |
Cylinder head
Any 5 cylinder 10v, K-Jet/fuel injected head, shimmed (not Hydraulic) lifters.
A bare head without valve gear is fine, but it must have camshaft bearing caps. example engine codes- WR, KG, WJ... But can be any other code that meets the above criteria, including normally aspirated injected heads. They generally use the same base casting. Minor cracks between valve seats may be acceptable, subject to reviewing pics. Larger cracks which have propagated further, and deep erosion of the inlet of exhaust tracts, mating face, of combustion chamber area will be a problem.
17-09-17, 11:58 PM | #2 | |
18-09-17, 06:28 AM | #3 |
MB head here if you want.
29-10-17, 07:48 PM | #4 |
Hi, both.
In both cases, hydraulic heads based on the later base casting, thus requiring some welding mods, among other things, to make them compatible with the block. Not insurmountable, but adds several stages to the process. We hopefully have a solution in progress, so we'll see. Cheers anyway.
29-10-17, 10:28 PM | #5 |
30-10-17, 04:14 PM | #6 |
Got a spare KK engine if you want it?
30-10-17, 07:14 PM | #7 |
Just be aware of the coolant channel difference in some of the castings.
WR/WN/WJ etc all appear the same, stuff like KK /KV has a different shaped channel that leaves the coolant leaking out if ones swapped over for the other. Easily fixable tho with chemical metal. |
30-10-17, 07:18 PM | #8 |
I currently have a head being prepped. Thanks..
I post up some details when progress is made.
