Members: 13,603 | Total Threads: 40,056 | Total Posts: 470,826 Currently Active Users: 841 (21 members and 820 guests) Welcome to our newest member, kiikurokj |
16-05-16, 04:35 PM | #1 | |
Special tools needed to change crankcase seals?
Hi All,
I am looking to change the rear main seal and front crankcase seal while doing other work. The engine is out of the car and I am about to remove the flywheel. Do I need any special tools to remove or install these two seals? Thanks, Ken |
16-05-16, 04:49 PM | #2 |
2079 and 2084 to remove the crank damper as the front crank oil seals behind it.
Just need to fabricate a locking device to undo the flywheel bolts and remove the flywheel to access the crank rear main and ideally a seal puller to remove the actual seal, screwdriver can be used but be careful! |
16-05-16, 04:51 PM | #3 |
Special Crankcase tools
Thank you!
16-05-16, 08:40 PM | #4 |
i use the 2084 on the front when removing the flywheel bolts
17-05-16, 04:27 PM | #5 |
