Classic Audi Classifieds section Parts Wanted » B2 window regulator M6 rubber mounts
Old 05-10-17, 04:23 PM   #1
andya
andya's Avatar
Default B2 window regulator M6 rubber mounts
As per title - their the ones that fix the motor to your door - on each side there are 2x 10mm thick rubbers and 1x 16mm. The original ones are hexagonal.
Does anyone know where to source them from?
1985 Coupe Quattro
1986 Coupe 1.8 weber carb
1987 Coupe 2.2 GT
Old 05-10-17, 05:02 PM   #2
sinbin5t
sinbin5t's Avatar
Do you mean the bobbins a bit like radiator mounts ? if so try these :-
ANTI-VIBRATION COMPONENTS
antivibrationcomponents.co.uk
Tel :- 0845 850 99 40
Old 05-10-17, 05:11 PM   #3
andya
andya's Avatar
Yes those are the ones, I was trying to remember the name of them - bobbins!
Great, thanks I'll try them. I dropped into a local firm to me this afternoon, probably a similar firm - they didn't have anything small enough, nor strong enough, majority of mounts were much softer.
1985 Coupe Quattro
1987 Coupe 2.2 GT
Old 05-10-17, 05:29 PM   #4
Davids
Not sure if this idea is any good when I needed some similar rubber mounts with a stud each side for the Cobra fan mount I used radio controlled engine mounts.
something like this
https://www.ebay.co.uk/p/4pcs-M6-Ant...d=252674655932
loads of choices, not sure if they are any good or not
Cheers
David
Davids is offline   Reply With Quote
Old 05-10-17, 05:37 PM   #5
moonwatcher
moonwatcher's Avatar
something like this
Cheers
David
I've used these on my MK1 TT to mount the fuel pump, filter etc.
spot on
Coupe Quattro 1985
Old 05-10-17, 06:21 PM   #6
sinbin5t
sinbin5t's Avatar
I got a catalogue from them, they do any size and i got some for my 5T, unlike a lot of these bobbins you can tighten these up and slacken them as many times as you want without damage.
Old 05-10-17, 07:38 PM   #7
andya
andya's Avatar
Thanks everyone for their input. Really appreciate it
1985 Coupe Quattro
1987 Coupe 2.2 GT
Old 05-10-17, 07:45 PM   #8
sinbin5t
sinbin5t's Avatar
Hope you get sorted wherever you go for them.
