Members: 13,473 | Total Threads: 40,056 | Total Posts: 470,823 Currently Active Users: 489 (2 members and 487 guests) Welcome to our newest member, eeweacejemol |
11-05-20, 01:29 PM | #11 |
I just made the diy locking tool and using a 6’ bar on the end of my socket bar it works a treat came off with no impact to the pulley.
im cleaning it now to check, I have a blast cabinet with fine grit should I blast it gently to clean up and get a better look? |
11-05-20, 02:31 PM | #12 |
It's usually the keyway and the areas where the 4 allen headed bolts are that any cracks will show.
I'd just wipe with a cloth and look at it in good light Have you separated the pulley from the vibration damper ?
11-05-20, 02:52 PM | #13 |
It’s the outer belt pulley I have off not the toothed one with the cam belt on it. I take it it’s the toothed cog that gives bother?
I haven’t ventured with that one yet. |
11-05-20, 03:00 PM | #14 |
yes - it's the toothed pulley which can crack.
11-05-20, 07:04 PM | #15 |
Belt
So checked the toothed crank pulley and all good no cracks or any damage at all under really good light, so see no need to take off and replace, it’s a genuine Audi part and very clean looking.
I checked TDC with a dowel down no 1 cylinder checked and marked with white paint dot flywheel at “0” and marked the cam pulley and the cam cover with white dots along with the crank pulley and casing as well. i removed plugs and turned over (by hand) 2 full rotations and all the painted dots line up perfectly. So I take it I’m safe enough taking water pump, idler pulley, ( in freezer overnight) And old belt off, reassemble again and hand turn to check nothing hitting or jamming? Last edited by falcoron; 11-05-20 at 07:07 PM. |
11-05-20, 07:20 PM | #16 |
sounds good. you should also remove the distributor cap and confirm the rotor arm is pointing close to #1 cylinder. There's a small mark on the distributor body.
It won' be exact because there will be a small amount of advance set. Not sure what engine you have but a KV is usually around 14 deg btdc with unleaded. your idler pulley shouldn't be in the freezer. It's a push fit onto the oil pump. If anything you want it slightly bigger - not smaller you will likely need a timing light to check your timing afterwards. No matter how careful you are, it always shifts slightly.
11-05-20, 07:25 PM | #17 |
Hi thanks yes it’s a KV engine
Always a great starter even after sitting 2 years fresh fuel and bingo no issues I’ll check the rotor arm as well Cheers |
11-05-20, 07:28 PM | #18 |
I had an interesting conversation with a mechanic friend (experienced and well respected) who said that on certain engines it was possible to change the cambelt by cutting the old one half way into the belt with a Stanley knife around the entire circumference, sliding the new belt into the space made, then cutting away the other half of the old belt before sliding the new belt fully home. Not sure it would work on our engines but an interesting idea.
11-05-20, 07:30 PM | #19 |
In theory you can but I wanted water pump changed as while on this far why not?
You can’t do that when cutting the old one like you say |
12-05-20, 08:52 AM | #20 |
Yep, false economy not changing the pump.
It's not a difficult job once you've got the front end off Last edited by Duffy3074; 12-05-20 at 08:59 AM. |
