Classic Audi Classifieds section Parts Wanted » Ur Quattro ABS Sensor
Old 11-02-19, 12:16 PM   #1
oliverjl
Default Ur Quattro ABS Sensor
I'm in need of an abs sensor for my MB quattro, I believe these are not the easiest thing to come across so if anyone has some inspiration then please let me know!
thanks
oliverjl is offline   Reply With Quote
Old 11-02-19, 12:38 PM   #2
Colin Aitchison
Colin Aitchison's Avatar
Front 443927803A Rear 857927807A, These are the two part numbers I can find, the WR, MB and RR seem to be listed as the same part number, from memory you can fit the front to the rear and rear to the front but there is a cable length issue but can't remember which but I will be corrected if wrong.
Old 11-02-19, 01:25 PM   #3
oliverjl
It's a rear one I was after, but I also got the impression I could use either a front or a rear to do the job
Old 11-02-19, 01:31 PM   #4
Colin Aitchison
Can't remember which, one has a longer wire.
