Members: 13,808 | Total Threads: 40,056 | Total Posts: 470,827 Currently Active Users: 766 (19 members and 747 guests) Welcome to our newest member, igohohecojale |
06-12-17, 04:51 PM | #1 | |
Removing Front Hub
Hi Forum, I am trying to remove the front hubs from my Audi Coupe quattro (b2).
I've got the correct socket size for it, but the hub is just spinning. How do I stop the hub and driveshafts from spinning? Should I have loosened the bolt while the brakes were on? hub.jpg Thanks |
06-12-17, 05:49 PM | #2 |
You should have loosened the bolt when the wheel was still on and on the deck. Will easily crack off with a nice long extension bar.
06-12-17, 05:51 PM | #3 |
Thank you, thought this might have been the case!
06-12-17, 05:52 PM | #4 |
06-12-17, 06:04 PM | #5 |
Easy mistake first time, we all do some crackers.
06-12-17, 06:08 PM | #6 |
06-12-17, 06:09 PM | #7 |
06-12-17, 09:24 PM | #8 |
You can put 2 wheel studs in and use a wheel brace or breaker bar type object to stop it rotating while you undo the hub nut.
Saves putting the wheel back on, lowering the car etc |
07-12-17, 07:12 AM | #9 | |
Buzzin, Been there done that, one thing is for sure, if you are going to work on your own car you are at some point going to f**k up, take it on the chin and accept it, it is still way better than putting it in to a garage and they f**k up and bill you for it. |
08-12-17, 09:53 AM | #10 | |
